20 Most Recent Mustek TwainScan 600 III EP Plus Flatbed Scanner Questions & Answers
How to install
Requires a ATAPI driver to be downloaded from the manufacturer website - then some application to import the image from the scanner. This can be Photoshop, Microsoft Word, Adobe Writer etc.
6/27/2011 6:16:18 AM • Mustek TwainScan... • Answered on Jun 27, 2011
My installation disk 1 is corrupt and i need to
Download 600 III EP Plus drivers from here
Hope this helps!!
Till next time, take care of your scanner.
2/7/2010 11:35:24 PM • Mustek TwainScan... • Answered on Feb 07, 2010
2answers
Drivers for scanner
http://mustek.com/product_resources/drivers/scanner/parallelport/600IIIepplus/win31-95-nt/63EP322.EXE
12/12/2009 3:50:50 PM • Mustek TwainScan... • Answered on Dec 12, 2009
Mustek EP A3 What power supply do I need for this?
Mustek EP A3, power supply input range is 100 Vac~250 Vac, 47~63 Hz, power consumption is 1.0 A, 15 V.
YBC (/\)
11/9/2009 4:19:53 AM • Mustek TwainScan... • Answered on Nov 09, 2009
Tipos de conectores para Power 120v - 15 volt
Mustek 600 III EP Plus scanner, it doesn't matter what is the adapter input voltage is (base on your local country power supply voltage), but as long as the adapter output plug in your scanner is +15VDC/1A Positive Polarity (positive inside and negative outside), then your scanner will work.
11/9/2009 4:01:10 AM • Mustek TwainScan... • Answered on Nov 09, 2009
My daughter has acquired a Mustek 600 III EP Plus
Mustek 600 III EP Plus scanner, Power adapter type output +15VDC/1A Positive Polarity (positive inside and negative outside).
11/9/2009 3:54:47 AM • Mustek TwainScan... • Answered on Nov 09, 2009
Friend gave it to me. hooked to computer but
Goto the company website and D/L the installation program...
9/12/2009 7:07:12 AM • Mustek TwainScan... • Answered on Sep 12, 2009
Flatbed scanner
take a volt meter and check the power at the end of the power adapter, sounds like it may be a power issue. if all is ok on that end does it still work on the old system? you may have to hook it back up to a working system and see if there is a firmware upgrade for it. Best of luck
9/10/2009 8:57:40 PM • Mustek TwainScan... • Answered on Sep 10, 2009
Drivers are available from the mustek web site in US or Taiwan. See http://www.mustek.com.tw/Download/driv_scanr/english/600iiieplus.html.
You need an AC power adapter if you don't have one. The original was an YHI Power Adapter, model YC-1015-15, Input 100-120V, 60 Hz, 0.4A, Output +15VDC/1A. I know because I'm reading it off of mine (I am the original owner of one, this is about 10 years old). You can find new ones on eBay for $10 plus shipping.
Finally, you need a cable that connects the scanner to the PC using parallel port technology. Both ends are 25 pin Female, and the cable itself is marked as IEEE 1284 compliant. Cable is AWM E101344 Style 20276 30V VW-1 Space Shuttle. Must have 25 pin female connectors, check eBay or http://www.driverforum.com/controller5/10421.html.
3/2/2009 2:06:28 AM • Mustek TwainScan... • Answered on Mar 02, 2009
Scanner Mustek mod. 600 III EP -[ Plus
Hola Julian: Eso que comentas es el power de tu scanner, puede ser conectado a cualquier toma corriente de tu casa con el adaptador adecuado y no necesariamente a tu computadora.
Pasa que algunas computadoras como la tuya tiene entrada de power para conectar este tipo de devices para darle corriente a los scanner, parlantes o cualquier device externo que necesite power.
Ese cable lo conseguis en cualquier store de electronica, es un bridge. (un puente de corriente entre tu compu y el scanner)
Sino la otra alternativa es conseguir un power supply para tu scanner. Eso es todo.
Aca tenes el power supply:
http://cgi.ebay.com/15HB-power-supply-ADAPTER-15v-1A-HP-Mustek-UMAX-scanner_W0QQitemZ370092779651QQcmdZViewItem?hash=item370092779651&_trkparms=72%3A1156%7C39%3A1%7C66%3A2%7C65%3A12%7C240%3A1318&_trksid=p3286.c0.m14
10/26/2008 6:35:39 AM • Mustek TwainScan... • Answered on Oct 26, 2008
Cant download
El cable entre la impresora y la computadora es este:
6ft IEEE 1284 Bi-directional Printer Parallel Cable, DB25 Male to Cen36 Male
10/9/2008 1:06:53 PM • Mustek TwainScan... • Answered on Oct 09, 2008
Mustek scanner Hang up
Hi leon,
Re-install again the driver of your scanner, machines hangs up because of the operating system got a problem working with it.
Enjoy
tnx
-micro
2/10/2008 1:15:21 PM • Mustek TwainScan... • Answered on Feb 10, 2008
Is ther a driver vor Mustek P3600 A3 Pro for Windows 10?
Yes, there is a driver available for the Mustek P3600 A3 Pro for Windows 10. The driver can be downloaded from the official Mustek website [1], or from the Windows Update tool [2]. Once the driver is installed, it is important to keep the drivers updated in order to maintain the functionality of your computer [3]. Additionally, using a driver updater such as DriverDoc can be beneficial in keeping all of your PC drivers updated [2]. <b>References:</b> <span>[1] <a href='https://www.mustek.de/drivers/index.php?stap=3&category=Scanners&product=p3600_a3_pro' target='_blank' class='text-purple-1 underline'>Scanners > P3600 A3 PRO - Mustek Driver & Support</a></span> <span>[2] <a href='https://www.solvusoft.com/en/update/drivers/scanner/mustek/p-3600-a3-pro/sub-models/' target='_blank' class='text-purple-1 underline'>Mustek P 3600 A3 Pro Drivers Download - Scanner - Solvusoft</a></span> <span>[3] <a href='https://www.driverscape.com/download/p3600-a3-pro-wia-scanner' target='_blank' class='text-purple-1 underline'>P3600 A3 Pro WIA Scanner Drivers Download</a></span> Written by Chatsonic
2/22/2023 8:50:29 AM • Mustek Office... • Answered on Feb 22, 2023
Service center in dubai
12/21/2022 8:31:36 AM • Mustek Office... • Answered on Dec 21, 2022
I'm looking for schematics Mustek Power Must UPS500. Can you help me?
fixya can help by suggesting that you direct your inquiry directly to Mustek.
11/11/2020 11:56:06 PM • Mustek Office... • Answered on Nov 11, 2020
Mustek TwainScan 600 III EP Plus Flatbed Scanner Logo
15 questions posted
Top Mustek Office Equipment & Supplies Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Mustek Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Mustek Office Equipment & Supplies
Most Popular Question
mustek ep a3 power supply need
  • Office Equipment & Supplies
