20 Most Recent
NEC ND-3500A DVD±RW Dual Layer Burner Questions & Answers
Dvd burning problem
i experience to your problem, this your burning a VOB is very fine but it your going to open at the same dvd burner you cannot see the files inside and also if you play that to your dvd-player,.. you know this type of burning speed is the matter, maybe you burn at maximum, keep burning your files at low speed for recognizing its buffer in good result..
Hp 740 lightscribe not working
Does it write data OK but not scribe??
Possibly it's just dusty after years of sitting. Get a foam swab or long q tip and wet with alcohol a little, and clean off the laser lens inside. Carefully. Or use one of those disk-based cleaner thingies.
I just replaced my old CD Writer/DVD player with
You need a driver for the soundcard that is in this PC (onboard audio?) Sometimes the setup will think it has the right card, and loads drivers, but it won't work. You need to look at the Motherboard if you have onboard and you should see VIA or some other chip pretty far away from the processor. The most common onboard audio is AC97, but a lot use CMedia and the drivers are not interchangeable. One way to try this is to go into device manager, hardware, and double click in Audio devices and find the soundcard. Right click, select properties, and hit uninstall. Then click scan and see what happens when it puts it back in. Remember to always reboot and you might get some sound. It sounds really lame, but when you put a new driver in a lot of Windows PCs will mute all sound and you have to go to Volume Control to get rid of it. I hope these ideas give you some things to try.
Dont write dvd ram (with
make sure that the dvd rw is getting enough power test all leads that are attached to the dvd rw including electrical extensions and make sure they have a secure connection or just replace them there might be bad/faulty your drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver roll back driver or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options update driver roll back driver or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer Close all open programs Click Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose DeleteAfter deleting the keys, close the registry editorReboot your computerOpen My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.hope this helps
My DVD Drive keeps asking
Does your computer _READ_ any CD disks?
Does your computer _READ_ any DVD disks?
If not, then your NEC writer has "failed" -- spend $40 to buy a new CD/DVD Dual-Layer reader/writer.
I have 2 DVD reader/writers.
It looks the software for writing the DVD's that you have is corrupted. you have tried installing the latest driver, but the situation that you are going through is almost same with 60% users.
Why don't you try downloading Nero Version 9. It is very user friendly software and very easy to use. It also writes Blu-Rays.
The 9th edition is released.
If need be you can download it from below website.
http://download.cnet.com/Nero-9-Reloaded/3000-2646_4-10028984.html
They this out and you will be all set. If you are set you are free to rate me.
Best of luck.
Roxio cd dvd burner has no burner on its icon and
Hello !
First, in Add/Remove programs, if Roxio is listed, uninstall.
If you downloaded the Roxio software, download again, save the file and reinstall.
If you purchased on CD, contact them to send another CD.
Hope this helps.
Im having trouble burning my
your files you are trying to burn arent the right format most likely, try using dvd flick it works great for me , almost anytype of video format it can put on to a disk for you,
Hi I have an LG
According to the log file, there was a spindle servo failure. The spindle servo is responsible for maintaining rotational speed accuracy. I'd say your drive is pretty much dead. See if you can read a disk in the drive. I wouldn't be surprised if it had a tough time just reading files.
