20 Most Recent
Canon Elph LT 260 APS Point and Shoot Camera Questions & Answers
Where can I buy the films. please.
Other than a few overpriced online suppliers, you don't. APS film is an obsolete system and is no longer manufactured. Even if you do find some, it's likely to be stale as it's all long out of date now and it can be tricky to find a lab which can now process it.
My canon elph is getting a magenta line on the
The film is being fogged by light leaking into the camera through a bad light seal. Due to the design of APS models the seals cannot be replaced. Either put opaque aluminium tape over the outside part which is leaking or retire the camera and replace it.
I cannot find where the memory card or film goes in this camera.
Your camera takes APS film. It's an obsolete system these days but the film and processing are still fairly easy to get.
The film loads into a compartment on the bottom of the camera; you open the compartment by turning the latch on the right hand end of the camera (as viewed from behind). The battery fits into a small compartment on the lower left back of the camera.
Click here to download a manual for your camera.
Enjoy your camera, and please take a moment to rate my answer.
What does the code
HELP this is a technicians error code and only tells you the camera is broken and unsuabel. the camera will have to be diagnosed and fixed by a technician. Because of the age, cost and tyoe of camera it may not be worth repairing. Try to find a used one or upgrade toa digital.
Canon Elph LT -35mm
You can view it as a pdf
here. Once it's open, click on the save icon in the upper left corner and save it to your computer.
Canon 12x36 is ii stabilization is not working properly. Stabilization
tends to want to stray.
Hello, I think dust, smudges, or fingerprints on the lenses can affect image quality and stabilization performance. Use a soft, lint-free cloth or lens cleaning solution to gently clean the lenses of your binoculars. Make sure not to apply excessive pressure or use abrasive materials that could scratch the lens surface. Moreover, when using image-stabilized binoculars, it's important to hold them steadily and avoid sudden movements. Rest your elbows on a stable surface or use a tripod if possible to minimize hand tremors. Ensure that you're using proper stabilization techniques to maximize the effectiveness of the stabilization feature.
Canon Digital IXUS 500 5.0MP is not powering on when CF card inserted.
In general Compact Flash Cards have to be formatted within the camera that is using them as they use a format proprietary to that camera. Also there are size limits on cards. If your camera will only take 16 Mb cards and you put a 32 Mb card in, it will not read it. It sees it as 'No Card Present'.
I think the other answer is an AI Answer Bot.
