20 Most Recent Canon EOS Rebel G 35mm SLR Camera Questions & Answers
2answers
How can i take the best pictures
you just cannot lurn to take good photos over night, it takes years of practice and hard work, mixed with sweat and frustration and you may still not take a good photo,,, it takes more that just "clicking away" to get it right, read books on this as many as you can just to get an idear of what and how to get the best composition and depth of field,, to make your photos stand out,,the photos you dont like just beleat,,,but please dont be put off by what other people say about your work,, its yours,, not theres! if you wont to show some to them only show them a fuw photos,,, not the lot, or you will bore them i have been taking photos for 50 years now, and i can honestly say iv only realy took about 30 that i realy liked,, others have won prises,, but i never realy liked them?
beauty is only in your eyes and not in every bodys eyes
just go out and take photos of what ever you like or takes your fancy
then realy look at them to see them from another way then take that
6/17/2019 6:04:29 AM • Canon EOS Rebel... • Answered on Jun 17, 2019
Rewind button stuck
Is there film in the camera? If it is then in a dark closet or change bag open the camera remove the film then manually rewind the film into its cartridge. Once the film is in the cartridge now you can look at the inside of the camera in the light, you should be able to get the rewind to work.
11/28/2016 3:37:58 AM • Canon EOS Rebel... • Answered on Nov 28, 2016
My Canon EOS Rebel G will not turn on.
7/18/2016 8:47:58 PM • Canon EOS Rebel... • Answered on Jul 18, 2016
The built-in flash auto pop-up was obstructed -
7/18/2016 7:50:37 PM • Canon EOS Rebel... • Answered on Jul 18, 2016
Como se apaga y como
7/18/2016 7:29:43 PM • Canon EOS Rebel... • Answered on Jul 18, 2016
2answers
Own DSLR camera would like to know the single best lens for the DSLR?
"Best" lens depends on several things: 1. What kind of pictures do you intend to take? 2. Do you mind a heavy leans? Some are 10 pounds or more. 3. Your budget. The "standard kit lens" that most come with is perfectly good for general photography. If you want to take architectural pictures, you'll need something different. If you want wide landscapes, you will need a wide angle, and if you want wildlife/bird pictures, you'll want a telephoto lens. It all really depends on what you intend to do... For example, I have a very wide lens I use for interior architectural pictures, medium telephoto for portraits, and a variety of long to very long telephotos for wildlife pictures... Yes, there are some extreme zoom lenses that cover 'normal" to "very long" telephoto. They're expensive, not especially sharp, and very heavy. Everything is a compromise.
1/5/2016 4:18:47 PM • Canon EOS Rebel... • Answered on Jan 05, 2016
Shutter button
You can get a working Rebel G body on eBay for about $20. You can use your current lens on the replacement body. A repair on your current camera would run at least $100. The replacement is far cheaper. Hope that helps,Bax
4/29/2015 6:04:41 AM • Canon EOS Rebel... • Answered on Apr 29, 2015
2answers
This is a 10 year
Very good possibility that the batteries you took out were corroded and left a black residue on the contacts in the camera at least it has some power getting through to signal the low battery. The battery door will most likely be not to bad but take a light and look down inside and see what the others look like. Long cotton tipped swabs with alcohol on it is a good start, then what I use is a little bit of sand paper formed around the eraser end of a pencil to sand off the contacts be gentle you don't want to bend or displace them. Once clean use the swab on it again and try the batteries make sure the batteries are good first. Another thing you might have problems with is the internal battery, it's something like a watch battery it keeps the internal clock ticking so to speak.
3/21/2015 2:12:12 PM • Canon EOS Rebel... • Answered on Mar 21, 2015
2answers
How to take the rewind option off?
how to video
12/22/2014 1:40:58 PM • Canon EOS Rebel... • Answered on Dec 22, 2014
The film automatically loads then rewinds when a new film canister is added
Hm. Well, the way this camera works is actually very clever. When you first load a film into it, it winds the entire film out of the cassette and into the camer. As each shot is taken, the film is rewound back into the film cassette. The advantage of this is that if the back of the camera is accidentally opened, the shots which have already been taken are already safely back in the film cassette and will not be damaged by the light ingress. However, your camera is behaving strangely. I would check that the electrical contacts where the film cassette goes in are clean. You can clean them using a cotton bud moistened with methylated spirits.
8/23/2014 3:10:38 PM • Canon EOS Rebel... • Answered on Aug 23, 2014
Why will my Canon EOS Rebel 35mm camera not turn on?
Probably battery compartment corrosion. Check for corroded contacts and clean them with a nail file or similar "tool". If that doesn't help, the corrosion has probably run into the circuit behind the contacts. If I remember well, that compartment is removable without great difficulty. I would get one of my relics but don't have the time today to dig through all those boxes!! Let me know if you need further help.
7/31/2014 8:43:28 PM • Canon EOS Rebel... • Answered on Jul 31, 2014
Film won't load
Bad motor gears
7/31/2014 4:23:42 PM • Canon EOS Rebel... • Answered on Jul 31, 2014
Cost of a complete fix it for a Rebel
$50-$90
7/31/2014 4:11:58 PM • Canon EOS Rebel... • Answered on Jul 31, 2014
Wont focus
have you got it on manual focus?
7/27/2014 12:12:41 PM • Canon EOS Rebel... • Answered on Jul 27, 2014
How to replace clock battery in eos rebel ll
Check the battery cap and the contact springs for any sign of battery leakage that may be shorting out the batteries. Clean with a hard eraser like a pen eraser. Make sure batteries are good, and are inserted properly, and that the battery cap is not damaged. Make sure the metal plate is in place on the battery cap. The back up battery is on the back of the front flexible circuit and you have to remove the mirror box to get to it. This is a complicated proceeedure that requires specialist knowledge and is not user servaciceable.
6/2/2014 11:47:44 PM • Canon EOS Rebel... • Answered on Jun 02, 2014
Unable to download to PC
Try NOT connecting your camera to your computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries. Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo management program.
5/8/2014 3:39:55 PM • Canon EOS Rebel... • Answered on May 08, 2014
I have a EOS Rebel
What's the problem? That's the way the camera is supposed to operate. The Live View feature, which lets you use the LCD for framing your picture, wasn't introduced until a later model.
5/8/2014 4:11:48 AM • Canon EOS Rebel... • Answered on May 08, 2014
your "clock battery" is just a very little rechargeable battery, that will charge as soon as you put in a fully charged battery in your camera. You should wait for at last 12 hours, before you remove the battery. and the little battery can keep the clock running for several days. Everything that is in the camera, only can be replaced by a skilled electronics engineer. The best thing you can do is contact a certified Canon repair centre and ask what it will cost to build in a new clock battery. But before you think it is a clock battery, make sure your battery is still in working order. Ask around if anyone you know has the same camera and borrow a charged battery for a few moments, to make sure it is not you camera battery.
4/25/2014 9:46:10 PM • Canon EOS Rebel... • Answered on Apr 25, 2014
Canon EOS Rebel G 35mm SLR Camera Logo
87 questions posted
Top Canon Photography Experts
old marine
old marine
ZJ Limited
ZJ Limited
Are you a Canon Photography Expert? Answer questions, earn points and help others
View Most Popular
Canon Photography
  • Canon Photography
Most Popular Question
just bought canon rebel xs film camera
  • Photography
