20 Most Recent HP Smart Buy 630 Intel Core i3-370M 2.40GNotebook - 4GB RAM, 500GB HDD Questions & Answers
When you connect something to an USB port for the first, don't hope to much. You have to be sure the computer has the correct software to recognise the hardware and can work with it. From Windows 7 and up, for most hardware that is certified with Microsoft, you can download the drivers from Microsoft. Lots of hardware is recognised when connected and will initiate a download from Microsoft. But not all hardware will do so and not all hardware is compatible with the new operating systems.
So to make sure your hardware is compatible, check the manual and find out, what you have to do so it will work on your computer.
HP Smart Buy 630... | Answered on Jun 22, 2014
lots of words and means just Dead PC. fans spin.
HP model number HP touchsmart. (no model stated at all)
its dead PC and screen is dead.
most PCs from HP have external display port.
of some kind, Display port or others, the manual covers this but your PC model was not told nor service tag model. told.
The PC is dead, and seems the power button is bad too.
here are some steps used on all laptops
1: remove the huge battery in the lap top, do not make excuses how hard it is to unplug , you bought it so do what must be done,
2: use the AC power pack only, (unpugged for 1hour first)
then plug it in, this pack
3: the PC must not self turn on. so push the power button now see it manually turns on.
4 the BIOS HP logo page shows and BIOS screens work like ESC, F10, F11,
5: if screen is still dead, use the external monitor port and
the Fn+F4 button as the manual tells you to do.
no PC stated at all not even class of PC, desk or laptop. and no parts are free.
the TOUCHSMART word does not tell what you own
that name used back to 2007, 13 years long.
IS THIS AND AIO all in one PC,?
does it have a power pack that in in the line cord
is it the right pack for the AIO>?
AIO PCs only have a few parts inside that are standard, RAM and HDD, all else is HP custom, making them as hard to repair as laptops, lacking those parts custom.
first learn to identify a PC first then tinker.
see examples below.
HP Computers &... | Answered 9 hours ago
yes indeed they do
HP Computers &... | Answered 2 days ago
what is this thing,
a desktop PC
a notebook, laptop PC
a printer 6122,
HP web site shows no such PC> at all.
the PC has HP service tag, and only that matters for help.
post the tags full information and no serial s/n number.
or start with a photo of it, so we can see it.
A PC, will not boot for many reason.
is the screen dead?
is the PC silent, fans dead.?
if a laptop does it run on AC pack with no huge battery plugged in?
the P6122F is a desktop, did you forget the P?
and is now so old HP has no support at all.
this pC was ,made in 2009 and no support now for it.
the RTC coin cell battery is now dead and the BIOS can not boot the
HDD like that, we replace 10 year old batteries, of any kind.
then get the BIOS screens working first,. no monitor stated so
it must be plugged in to the matching jack on the rear, VGA to VTA
DVI to DVI or DP to DP.
HP Computers &... | Answered 3 days ago
ilioSystemService is part of system mechanic program if its missing opr corrupted try reinstalling the system mechanic.if it wont fix the problem. contact http://www.iolo.com/customercare/technicalsupport.aspx to help you sort out that problem file. thanks
download and install codec for windows media player to play dvd movies from http://www.free-codecs.com/download/K_lite_codec_pack.htm
or download vlc player that play dvd directly from
http://www.filehippo.com/download_vlc/
HP Computers &... | Answered on Nov 30, 2019
your web connection is too slow.
non stated by you, let me guess wifi?
do internet speed test yet, goggle that, bingo.
no location stated., home, or starbucks or?
do other PCs, work , in same place? hummmmmm
windows 8.1 that? what do you mean.by 8.1
no pavilion PC model stated., not even desktop or laptop.
this is 2009 cam, and runs XP/vista/w7 software only.
lost the CD that came with it?
the maker is Vivitar, only they can source software.
id read this first.
https://www.lifewire.com/vivitar-support-2625707
i have working and fully max upgraded xw4600 , sister to yours.
MBR is limited to 2GB,(approx)
the OS must be 64bit, to go GPT,
are you saying to boot from this drive, full system not told
I run SSD as boot drive, 128GB. then drive 2 non boot can be any thing I want in w10 64bit, nobody uses w7, now, it dies, Q1, 2020.
UEFI safe boot needs, OS RELOADED, and to GPT.
and 64bit OS, it is NOT a BIOS issue. but do upgrade BIOS,
UEFI does not own GPT, you can run legacy with GPT, microsoft.com has full pages telling you how to do that.
I have w10 64bit, v1903 on mine. now. runs like champ.
once booted the OS runs the HDD not BIOS, a fact.
when you fresh load w10 64 from ISO the OS installer will set that 3TB as GPT , regardless of BIOS.
try it see.
but SSD drive there booting is always best. even on all my servers.HP and DELL.
you can set up w10 to put all data on drive, E: 3TB
or have 2 partitions there, programfiles and DATA.
then OS owns the SSD, alone.
hope that helps some.
HP Computers &... | Answered on Nov 28, 2019
AIO PCs seem to love to die,
the PC
so PC is silent, means lost of power, check AC cable, make sure to use wall jack AC not a power strip.
AIO are not easy to fix, most parts in side are non standard
so that makes them a pain.
why not get shop to fix it.?
did you hold the power button in for 5 full seconds as page 2 in your service manual directs.?
repeat that 2 times, 1st to end buggy sleep drivers, 2nd to hard power it on,
if that fails the , PSU bad top cause. (silent PC)
you need to ask HP, that, it's laptop right?
only they can undo that, (by design)
hp 15 is not the full model name:
example #1, the service tag is read first, then told what it is.
HP 15-bs031wm then go here and ask HP, what to do. notebooks
https://h30434.www3.hp.com/t5/Notebooks/ct-p/Notebook
HP Pavilion Slimline s5000 (s5100z)
fans spin, ok,
DVD tray enjects.
does this PC have the optional
the first 5000 was made in year 2003
then laters for VISTA.
id have to see your service tag info to wax smarter.
hp forum can help try that? hp.com
I guess the VGA port is dead, ?
most old PC had 2 ports, 1 on the card, one on the main chassis rear . if the card GPU vga is present only it works.
if you remove the GPU the main VGA port is live.
I cant see rear of your PC and seeing MATTERS.
the common failures are:
RTC coin cell dead.
HDD bad, (most are this old)
and PSU bad.
in that order.
You don't have the codecs needed to watch the movie.
Download some codec pack, or just use VLC.
Link to VLC
HP Computers &... | Answered on Nov 20, 2019
Tip
Why is Hp Printer Showing Offline on Windows 7
Folks are you afraid about your hp printer is offline status. In any case, this isn't added agilely to get the breach why is hp printer offline issue. Old you annex to analysis your availability on your hp printer. In the accident that you access captured your hp printer settings and ache isn't abiding so on the off adventitious that you accretion to administrate advance intends to get hp printer offline on windows 10 to on the web. That we proclaimed below for this hp printer is a broken issue.
on Nov 13, 2019 | Computers & Internet
As the computer is powering on;
Pressing the F11 key repeatedly,, click Troubleshoot, and then selecting HP Recovery Manager
HP Computers &... | Answered on Nov 13, 2019
Access google and enter, "how to restore HP laptop to factory defaults". Be mindful of the data copy/backup steps as this is important.
Warning to FixYa readers -DO NOT CALL THE FAKE TECH SUPPORT NUMBERS POSTED ALL OVER THIS SITE. These phony support numbers or web links send you to criminal call centers where they will install malware, steal ID and/or extort money from you . Please only ever use the support contacts from the official company website {edited by volunteer Expert}
FixYa Experts: Once you have reached a certain number of answers, then you can Edit and Delete these spam posts too, so they don't victimize unwary users. By my estimate, 4 of your fellow volunteer Experts are currently deleting 5000 or more spams per day, and it's not keeping up with the flood. Please help us out.
DO YOU HATE ALL THE SPAMMERS AND SPAMMING HERE ON FIXYA ??? USE ANY NUMBER HERE. CALL A SPAMMER AND HAVE SOME FUN TODAY!! ALL TOLL FREE TOO!!
THIS IS A COLLECTIVE PHONE LISTING OF ALL THE SPAMMERS HERE ON FIXYA. WE SUGGEST YOU DONT CALL ANY OF THEM UNLESS YOU KNOW WHAT YOU ARE DOING !!
1-85O-8I2-4OO9 1-8OO-8O3-1O69 1-888-499-5520 1-877-769-0969 1-888-499-5520 1-8OO-828-O294 888-348-1833 1-888-444-6538 1-855-616-7697 l-855-892-OO6O 1-888-570-9791 1-855-26O-OO64 1-855-536-5666 1-844-24O-9111 1-8OO-55O-5195 1-845-481-1722 1-855-616-7697 1-844-819-3382 1-855-221-4867 1-845-481-1722 1-800-258-1449 1-845-764-4808
IF YOU KNOW WHAT YOU ARE DOING HAVE SOME FUN WITH THESE LOSERS AND LETS BEAT THEM AT THEIR OWN GAME.. CARRY ON15
HP Computers &... | Answered on Nov 12, 2019
HP Smart Buy 630 Intel Core i3-370M 2.40GNotebook - 4GB RAM, 500GB HDD Logo
1 questions posted
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • HP Computers & Internet
Most Popular Question
done solve usb port problem hp630 core
  • Computers & Internet
