20 Most Recent
Canon EF 70-200mm f/2.8L USM Lens Questions & Answers
How do I go go to a central focus point vs. having
This is done in your camera not with the lens. On most Canons there is a button with a picture of a box with focus points in it. You hold this down whilst turning your main dial (the one you use to change shutter speed) this will cycle through your focus points.
On the 40D and most other cameras this button should be at the very right hand top corner of the back of your camera.
9/15/2009 12:59:02 PM •
Canon EF...
Answered
on Sep 15, 2009
Canon EOS 1D won't "read" my 70-200mm Canon lens.
HI I AM SAGHA REPAIRER FROM MUMBAI. I THINK YOUR CANON I D HAS A LENS SENSOR SWITCH INSIDE THE BODY WHOSE PLASTIC STUD CAN BE SEEN INSIDE THE BODY MOUNT WHICH COULD HAVE BEEN WORN OUT WHICH GIVES THIS PROBLEM BUT THIS IS NOT SOLVABLE BY YOURSELF GET IT DONE FROM REPAIRER.DO REPLY ME AS SOON AS YOU GET IT DONE.THANK YOU.
8/2/2009 5:08:38 PM •
Canon EF...
Answered
on Aug 02, 2009
Canon 12x36 is ii stabilization is not working properly. Stabilization
tends to want to stray.
Hello, I think dust, smudges, or fingerprints on the lenses can affect image quality and stabilization performance. Use a soft, lint-free cloth or lens cleaning solution to gently clean the lenses of your binoculars. Make sure not to apply excessive pressure or use abrasive materials that could scratch the lens surface. Moreover, when using image-stabilized binoculars, it's important to hold them steadily and avoid sudden movements. Rest your elbows on a stable surface or use a tripod if possible to minimize hand tremors. Ensure that you're using proper stabilization techniques to maximize the effectiveness of the stabilization feature.
Canon Digital IXUS 500 5.0MP is not powering on when CF card inserted.
In general Compact Flash Cards have to be formatted within the camera that is using them as they use a format proprietary to that camera. Also there are size limits on cards. If your camera will only take 16 Mb cards and you put a 32 Mb card in, it will not read it. It sees it as 'No Card Present'.
I think the other answer is an AI Answer Bot.
I have a Canon IXY digital 930 IS camera and its FUNC.SET. button(aka ok button) is not working and i want to reset the camera because all functions aren't working properly.so how to reset the camera.
To reset your Canon IXY Digital 930 IS camera, you can follow these steps:
- Turn off the camera: Make sure the camera is powered off.
- Locate the menu button: On the back of the camera, you should see a button labeled "MENU." This is typically used to access the camera's menu settings.
- Press and hold the menu button: With the camera powered off, press and hold the MENU button for a few seconds.
- Power on the camera: While still holding the MENU button, press the power button to turn on the camera. Continue holding the MENU button until you see the camera's menu screen.
- Reset the camera: Once the menu screen appears, navigate through the menu options using the arrow buttons on the camera. Look for a "Reset" or "Factory Reset" option. The specific location and wording may vary depending on the camera model. Select this option to initiate the reset process.
- Confirm the reset: The camera will likely prompt you to confirm the reset action. Follow the on-screen instructions to confirm and proceed with the reset.
- Wait for the reset: The camera will perform the reset process, which may take a few moments. Once the reset is complete, the camera settings should be restored to their default values.
Canon powershot A530 gives me memory card error works with my 16Mb SD card but not with my new 2GB SD card
If the original card works this could be an issue with the card itself. If you can, connect the 2Gb to a computer and see if it still gives you problems. While you have it connected 'Format' it. This is basically resetting the memory card. Try this.
Connect the card to the computer. Open the File Explorer, (the little folder shaped icon), at the very bottom left of the screen. The memory card should be listed in the box on the left side. Right click the card, (press the Right mouse button once). Another box should appear with a list including the word 'Format'. Click it and follow the instructions. When finished use the same Right Click method and 'Eject' the card. This just tells the computer your removing the card. Retry it in your camera.
