20 Most Recent Canon PowerShot SD1300 IS Digital ELPH Camera Blue - CanSD1300blu Questions & Answers
Before you can download any pictures from your camera, you have to install the software that was on the CD that came with your camera. Canon also allows you to download the latest versions from there web side, when you go there.
While installing the Canon Zoombrowser, the correct drivers are installed too.
Canon PowerShot... | Answered on Jan 30, 2014
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
Canon PowerShot... | Answered on May 03, 2012
NEEDS BATTERY
Canon Cameras | Answered on Nov 08, 2019
I think it is due to the extensive choice of quality lenses.
Canon Cameras | Answered on Nov 05, 2019
Contact Canon directly to inquire.
Canon Cameras | Answered on Oct 26, 2019
The camera is trying to process information to or from the memory card. If the status does not change after a few minutes, you may have a damaged memory card. Turn the camera off. Remove the memory card and inspect it. Reinsert the memory card. Can you view photos on the LCD by pressing the arrow button? If so reconnect to your computer. If not, you most likely have a damaged memory card. Try inserting the memory card into a card reader connected directly to your computer. This may be able to still read the card when your camera cannot.
Canon Cameras | Answered on Oct 03, 2019
Sounds like your imaging sensor has failed and is not recording blue or green tones. Take your camera to a good camera store or send it to Canon for a service estimate.
Canon Cameras | Answered on Oct 01, 2019
It sound like a fault with the auto connection probably a broken or cracked ribbon cable. May well need a replacement
Canon Cameras | Answered on Sep 24, 2019
If it focuses OK manually but doesn't on auto you may have a crack or broken ribbon cable in the lens.
Check that the sandisk ultra microsdhd 1 is compatible with the Legria FS306
Does live view work with other lenses? if so you may just have a dirty or faulty connection re the Tamron 70-200.
You need to check out the correct settings as the flash sync speed for you 6D ii is 1/180th which you should be able to use at 1/200th so only being able to get less than 1/160th would indicate incorrect setting in the external flash mode or a slight fault.
Canon PowerShot SD1300 IS Digital ELPH Camera Blue - CanSD1300blu Logo
3 questions posted
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
View Most Popular
Canon Cameras
  • Canon Cameras
Most Popular Question
canon powershot sd1300 won 39 t connect
  • Cameras
