20 Most Recent Canon Digital Rebel XT / EOS 350D Body only Digital Camera Questions & Answers
I've uploaded an expanded schematic of the 350D to this site which should hopefully appear in the next day or two - it gives you an idea of how to disassemble without being explicit instructions.
Hopefully this will help.
Canon Digital... | Answered on May 16, 2014
kindly format you SD card first then try again to take a picture .
Canon Digital... | Answered on Dec 08, 2012
you probably need to uninstall
and re-install the canon program
and ,if you want to fix launcher.exe,There are 3 step to repair launcher.exe stopped working error
If you got launcher.exe stopped working error then there is a 94% chance that your computer has registry problems. To repair launcher.exe stopped working error you need to follow the steps below:
* Step 1 - Download a Perfect Optimizer,install this error repair tool.
* Step 2 - Click the Repair All Button.It will scan you pc for Free.
* Step 3 - Then click the Repair All Button again and your done! It is very easy to repair launcher.exe stopped working error.
Canon Digital... | Answered on Dec 13, 2011
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Canon Digital... | Answered on Apr 05, 2011
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Canon ZoomBrowser or Picasa ( http://picasa.google.com ).
Canon Digital... | Answered on Mar 19, 2011
there is a mechanical control next to the viewfinder, adjust it to it center postition
Canon Digital... | Answered on Mar 15, 2011
You can download Canon software from
http://www.usa.canon.com/cusa/support/consumer/eos_slr_camera_systems/eos_digital_slr_cameras/digital_rebel_xt#DriversAndSoftware
You might want to consider NOT connecting your camera to your computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Canon Digital... | Answered on Jan 31, 2011
This is not a consumer fixable problem. Only a repair facility can do this.
Canon Digital... | Answered on Jan 20, 2011
Take a look at it from the front and see if the flash will pop up all the way ..usually, (on other models too) this error appears when the flash is not fully popped out ..and something is on the way ..
Either manually see if you can get it out ..or ..look careful cause when the flash is out ..in the right hand side when you face it ..there is a small prong that it is not supposed to be in contact with it ..and it is actually a switch informing the flash out position ..if the flash is not all the way out ..this is slightly touching it ..and i need to be released ..
Canon Digital... | Answered on Jan 12, 2011
Try getting new trusted brand batteries like duracell, And also if it forces you to change the D/T just change it. Also try getting a new memory card. (trusted brand). If none of this works then there might be a prob. Maybe someone dropped it. Try asking the company 2.
Hope this helps
Canon Digital... | Answered on Jan 07, 2011
You can use a card reader to download to a folder you create on your desktop. From there, you can do what you need with the pics.
Canon Digital... | Answered on Sep 14, 2010
Having received no response in over a month, I assume this is no longer a problem.
Canon Digital... | Answered on Jun 02, 2010
Hi, If the batteries run down completely while the camera is still open, it may not start up again when new batteries are installed. But if you remove the memory card, then install the new batteries, when you turn it on it should come back to life.
Digital cameras for the most part should only be used with rechargeable NiMH batteries (if you still have your instruction manual, open it to the "batteries" section. Pretty sure you'll see a statement similar to what I've just said).
check whether your batteries are actually making contact with the battery posts, and that these posts are clean. If not, bend the posts up/down a little, and maybe clean them with a little rubbing alcohol on a Q-tip
Canon Digital... | Answered on Apr 14, 2010
Canon Digital Rebel XT / EOS 350D Body only Digital Camera Logo
39 questions posted
Top Canon Cameras Experts
old marine
old marine
Ekse
Poul Brinchs Larsen
Are you a Canon Camera Expert? Answer questions, earn points and help others
View Most Popular
Rebel Canon
  • Rebel Canon
Most Popular Question
eos digital rebel xt350d no installer
  • Cameras
