20 Most Recent Casio Exilim EX-Z30 Digital Camera Questions & Answers
When i try to upload pics to my computer it says there are no new pics available
Try transferring the photos to the PC using the camera and see if this works.
1/27/2013 3:31:17 AM • Casio Exilim... • Answered on Jan 27, 2013
I need to date stamp
The date and time (and a lot more) are automatically stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
1/26/2013 12:01:46 PM • Casio Exilim... • Answered on Jan 26, 2013
Hi my camera as the lens stuck it makes an error
Try the procedures in this tip.
1/26/2013 12:01:20 PM • Casio Exilim... • Answered on Jan 26, 2013
Need to print date on photo
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
1/26/2013 12:01:07 PM • Casio Exilim... • Answered on Jan 26, 2013
I put pictures on my sd card useing my camera but when i try to upload them to my computer it says that there are no new pictures to upload
ALTERNATE WAY TO TRANSFER PHOTOS AND VIDEOS TO A COMPUTER If your photos and videos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos and to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
1/26/2013 8:05:21 AM • Casio Exilim... • Answered on Jan 26, 2013
Where is the volume of Casio EXILIM 10.1 mega
  1. In the REC/PLAY mode, press "menu"
  2. Select the "set up" tab, select "sounds" and press > (right directional key)
  3. use the "up" and "down" keys to select "volume"
  4. press "left" and "right" to adjust the volume. press "set" when you're done.
There you go. good luck and happy shooting!
10/1/2011 11:46:47 AM • Casio Exilim... • Answered on Oct 01, 2011
I cant upload my pics
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
4/20/2011 5:18:30 PM • Casio Exilim... • Answered on Apr 20, 2011
I want to take black and white photos on my Casio
The EX-Z30 doesn't have a black-and-white mode. You can convert a color picture to black-and-white using just about any photo-editing program on a computer, and this will give you better control over the conversion than any camera.
3/15/2011 9:11:26 PM • Casio Exilim... • Answered on Mar 15, 2011
I want to know the iso speed
Hi. You can set the ISO through the menus on P.86 of the manual,
Instead, see P.89 of the manual, you can assign ISO to the left/right keys,
This is so that you can cycle through the ISO settings in REC mode,
You can also specify what settings, including ISO, are put in place when you next switch on, see P.90
If you do not have access to a manual you can download it free at:-
http://www.retrevo.com/support/Casio-EX-Z30-Digital-Cameras-manual/id/200ag205/t/2/
In playback I don't think you can display on the camera the ISO of the images which you have captured, but the EXIF data, including ISO, can be viewed on PC with an EXIF reader/viewer/editor or using an add-on to Firefox browser call FxIF.
Hope this helps!
12/28/2010 2:45:57 PM • Casio Exilim... • Answered on Dec 28, 2010
2answers
:( please help - lens problem
time for a replacement camera...as the repair wouldn't be to expensive to consider.  Use your wrist strap
4/18/2010 9:11:57 AM • Casio Exilim... • Answered on Apr 18, 2010
When the digicam takes picture the shot is all
This sounds like a CCD problem. You will need to get the camera checked at a repair shop.
3/11/2010 9:30:05 AM • Casio Exilim... • Answered on Mar 11, 2010
Lens error!
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
2/23/2010 6:15:52 PM • Casio Exilim... • Answered on Feb 23, 2010
How do you charge the battery? i don't have a lead
The camera uses a NP-40DBA battery, which fits into a BC-30L charger. The battery does NOT charge in the camera.
If you've lost the charger, you'll have to buy a Casio or a third-party replacement from your favorite local or online store.
2/4/2010 9:52:23 PM • Casio Exilim... • Answered on Feb 04, 2010
Lens won't close
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
12/31/2009 12:44:50 AM • Casio Exilim... • Answered on Dec 31, 2009
Shutter doe'snt work casio exilim ez-z30
oh this happened with my old 2008 version of the casio. i pressed on the lens/shutter to hard. and it was crooked but i popped it back in place, it makes a weird clicking sound when i try to turn it on and there's a system error. u could get the lens/shutter fixed for 100's of dollars or just buy a newer version of the camera. i just bought the newer version of the camera. btw, don't get a new memory card! keep the one u have.
10/24/2009 6:57:28 PM • Casio Exilim... • Answered on Oct 24, 2009
Casio digital camera exilim z30/z40
gurlll u dome
12/23/2008 9:11:43 AM • Casio Exilim... • Answered on Dec 23, 2008
SYSTEM ERROR
i can not insert link with computr
6/17/2008 10:09:56 AM • Casio Exilim... • Answered on Jun 17, 2008
Casio Exilim EX-Z30 Digital Camera Logo
24 questions posted
Top Casio Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Casio Camera Expert? Answer questions, earn points and help others
View Most Popular
Exilim Casio
  • Exilim Casio
Most Popular Question
repair
  • Cameras
