20 Most Recent NEC SuperScript 860 Laser Printer Questions & Answers
2answers
NEC SuperScript 860 Laser printer
In a word.... no. The NEC SuperScript 860 is a black and white laser printer. It does not print color.
1/26/2015 7:27:03 AM • NEC SuperScript... • Answered on Jan 26, 2015
HP LaserJet P1005 accepting print jobs acceting for msword but not detecting the printer for excel why
If you print from MS-WORD, the problem is not the printer.Check if you have defined the print area -> 1. Select the area to be printed. Two. design you page 3. And as you set print area. 4. Prints.
11/13/2013 9:43:45 PM • NEC SuperScript... • Answered on Nov 13, 2013
Cat de performanta este
Black Print Speed: 8 ppm (viteza printare negru) Total Media Capacity: 200 Sheets (capacitate totala) Max Resolution (BW): 1200 x 600 dpi --\>Rezolutie maxima
1/6/2011 8:01:05 AM • NEC SuperScript... • Answered on Jan 06, 2011
How do I create a
DEGREE AND OTHER SYMBOLS ARE LOCATED IN OFFICE SOFTWARE LIKE MS WORDS. IN WORDS YOU MAY PRESS "INSERT" THEN "SYMBOLSmoz-screenshot.png" THEN CHOOSE YOUR SYMBOL THEN ENTER
8/16/2010 6:01:18 AM • NEC SuperScript... • Answered on Aug 16, 2010
I have on old printer, and haven't CD to insllat
Hi, if you paste the following into your browser it will take you to the download page for you printer. Kind regards
3/14/2010 9:39:52 AM • NEC SuperScript... • Answered on Mar 14, 2010
NEC SuperScript 860 Printer service Manual
You can try www.eserviceinfo.com.
8/19/2009 2:28:05 PM • NEC SuperScript... • Answered on Aug 19, 2009
2answers
Nec superscript 860 printer driver
Hi Richard,
As you might all ready know, this printer is not supported by Vista,  pasible solution: - if you have another "old" computer, you could install your printer on that, and share it, that way you can printe via the other computer. in case you want drivers for all other software, here is the link.
regards /Teis
7/13/2009 10:42:01 PM • NEC SuperScript... • Answered on Jul 13, 2009
I want drivers to my nec
Check this nec page it should have all the drivers if available.
http://printers.necam.com/printers/drivers/driver3.cfm?s=4&p=361
5/5/2009 12:17:23 PM • NEC SuperScript... • Answered on May 05, 2009
Superscript 860
If you can reach the sheet, you may apply a lot of force on in without the risk of destroying the printer.
5/5/2009 6:21:18 AM • NEC SuperScript... • Answered on May 05, 2009
2answers
Where do you get a refill cartridge for the NEC superscript 860
go to   www.precisionroller.com  they have everything and are a good company...
5/4/2009 10:43:33 PM • NEC SuperScript... • Answered on May 04, 2009
Nec 860 laser printer fuser unit
remove cartridge and leave top door open, then remove two screws in back ; open front sheet panel to find two screws to remove then remove outer case carefully AND PLACE ON LEFT SIDE BECAUSE THERE'S A RIBBON WIRE ATTACHED.
there are 4 screws holding the fuser unit in place, remove AND LIFT OUT BY ROLLING TOWARD YOU to reveal 2 screws to access the red roller assembly!
In my case there was a very tightly wound piece of paper stuck in there not visable without removing the screws on the fuser unit!
12/18/2008 10:06:32 PM • NEC SuperScript... • Answered on Dec 18, 2008
Nec superscripct860
I bought a new compaq computer and I need the software to install the superscript 860 lazer printer.
10/3/2008 2:56:18 AM • NEC SuperScript... • Answered on Oct 03, 2008
Problem in feeding papers
Sounds like the pick up rollers are either dirty or are worn out. You can try cleaning them with a soft lint free cloth. Just look for a roller or wheel looking item where the printer picks up the paper. If they feel very smooth then they maybe worn out and may be replaceable. Check the owner's manual or the manufacturer's website to find out.
Hope this helps!
5/11/2008 9:40:08 PM • NEC SuperScript... • Answered on May 11, 2008
Paper does not come all the way through the printer
This is more of a workaround than a fix: I open up the front door and use the Face-Down Tray to collect all my printouts.
4/30/2008 5:50:06 AM • NEC SuperScript... • Answered on Apr 30, 2008
How do I turn on my P350x NEC projector and how to reset the timer?
1. To turn on your NEC P350x projector, press the power button on the top of the projector. 2. To reset the timer on your NEC P350x projector, press the Menu button on the remote control. Then navigate to the "Timer Settings" menu and select the "Reset" option.
12/27/2023 6:09:58 PM • NEC Office... • Answered on Dec 27, 2023
NEC IT3640D copier. We have a malfunction code C4101 on it. What can we do?
All here and also the Service Manual in Scribd.
C4101 error code Bizhub 350
Copytechnet https://www.copytechnet.com > ... > Konica Minolta Apr 23, 2010 - C4101 code at power up. Description: C4101 code at power up. Solution: PROBABLE CAUSES: 1. Failed PWB-A (Mechanical CB). Missing: NEC ‎IT3640D
IT40D Series Service Manual ' PDF
Scribd https://www.scribd.com > doc They are sharp and may hurt you. Be sure not to leave the packing material inside the system. It may cause a system malfunction or a fire.
SOLVED: Error code c4101 - Konica Minolta
Fixya https://www.fixya.com > ... > Bizhub 362 Copier Oct 25, 2012 - THE COPIER DISPLAYS ERROR C4101. C -4101 Polygon motor error. Change the polygon motor ,if you can not reset the malfunction code.
8/8/2023 3:06:42 PM • NEC Office... • Answered on Aug 08, 2023
NEC projector M322X indicates light but cannot turn on
Based on the information provided, it is possible that there may be an issue with the projector's power button or internal components. It is recommended to try the following troubleshooting steps: 1. Check the power source: Ensure that the projector is properly plugged into a working power outlet and that the outlet itself is functioning correctly. 2. Reset the projector: Some projectors have a reset button or option in the settings menu. Try resetting the projector to see if this resolves the issue. 3. Check for internal issues: If the above steps do not work, there may be an issue with the projector's internal components. It is recommended to contact a professional technician or the manufacturer for further assistance. In summary, if a NEC projector indicates light when plugged into a power source but does not turn on when the power button is pressed, it may be due to issues with the power source, internal components, or other factors. Troubleshooting steps such as checking the power source and resetting the projector may help resolve the issue, but professional assistance may be required if these steps do not work.
6/21/2023 8:32:42 PM • NEC Office... • Answered on Jun 21, 2023
NEC NP PA550w - Replacing polarizing filters
If they are not physically broken, brake cleaner and cotton wool will get them clean. Don't put them back in the wrong way around!
10/19/2022 11:59:33 PM • NEC Office... • Answered on Oct 19, 2022
2answers
I have Windows 11. Is there an available driver for my NEC SuperScript 860 that will allow it to work on my PC?
Don't know if this will work as I don't run anything from Microsoft. I sue a proper OS; Linux. https://driversol.com/drivers/printers/microsoft/nec-superscript-860
8/18/2022 2:57:36 AM • NEC Office... • Answered on Aug 18, 2022
2answers
I bought a NEC NP M300W Projector and the picture was real weak and dim, so I ordered a new lamp and put it in and still the same problem.
M300w use LCX102 LCD panels Sony Lcd panel is not durable the font strokes are weak, The color of the black font is not black enough It means the lcd panel is failed there are 3 lcd panels in the projector Red Green Blue 3 lcd panels are failed you need a new whole prism block with 3 lcd panels
3/5/2022 8:07:50 PM • NEC Office... • Answered on Mar 05, 2022
NEC SuperScript 860 Laser Printer Logo
21 questions posted
Top NEC Office Equipment & Supplies Experts
Alexander
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
SuperScript NEC
  • SuperScript NEC
Most Popular Question
get refill cartridge nec superscript 860
  • Office Equipment & Supplies
