20 Most Recent Bemis 697 400 Humidifier Questions & Answers
When I turn on the
If you can easily get to motor I would unplug unit and check motor to see if it turns freely. If it does I would plug the unit back in and see if the humming noise is coming from motor. Ifyou decide that the motor is the source of the noise and you can do so safely spin the fan and see if it will try to run, If it does I would unplug unit and give fan motor and blades a thorough cleaning. Clean any hair,lint or dust from aaround motor shaft. A small motor like these does not take much to slow or stop them. Plug it back in and try it. If it stiil does not work I would replace the motor. Hope this helps. Thanks
12/30/2010 8:40:58 PM • Bemis 697 400... • Answered on Dec 30, 2010
Broken fan blade on the 697400 humidifier
Hay Richard -- Little suckers spin to fast for gluing. Take the fan blade off , mark one side before you remove it ex: put an x on the side that is facing the wall. Take blade to a Johnstone supply house. Should be one near you somewhere, they are national. The guys there are usually very good at matching up fan blades. Make sure you keep the one you have with the mark on it. When you get home install the new blade the with the side out that was on the old blade. Hope that helps
3/6/2009 6:43:55 PM • Bemis 697 400... • Answered on Mar 06, 2009
Bemis Water Wick 6974Tanks will not disperse water properly
sounds like new caps should solve it, but have you tried soaking the old caps in vinegar overnight? these guys are not the only ones, but they have the correct caps in stock at a pretty good price http://www.marbeck.com/humidifier_parts_bemis.html hope this helps :)
3/15/2007 8:21:55 AM • Bemis 697 400... • Answered on Mar 15, 2007
Model 696-400. Why does it always empty the right tank first?
It may have been designed that way or could be faulty design.
1/2/2021 5:16:15 PM • Bemis... • Answered on Jan 02, 2021
Bemis humidifier
makes air moist
11/28/2020 5:07:37 PM • Bemis... • Answered on Nov 28, 2020
How to replace filters and wicks for bemis water wick model 6974
Try contacting vendors for instructions and assistance. Example: https://www.appliancefactoryparts.com/humidifiers/bemis/6974.html
2/17/2019 1:45:18 AM • Bemis... • Answered on Feb 17, 2019
0answers
0answers
0answers
Dp3 200 manual
Be the first to answer 1/20/2014 5:15:01 AM • Bemis... • Posted on Jan 20, 2014Be the first to answer
Air flow is backwards after I replaced motor
reverse the wires going to the motor
1/19/2014 5:52:11 AM • Bemis... • Answered on Jan 19, 2014
0answers
Need manual/modelH12300
12/28/2010 9:00:40 PM • Bemis... • Answered on Dec 28, 2010
Bemis 697 400 Humidifier Logo
6 questions posted
Top Bemis Humidifiers Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Bemis Humidifier Expert? Answer questions, earn points and help others
View Most Popular
Bemis Humidifiers
  • Bemis Humidifiers
Most Popular Question
broken fan blade 697400 humidifier
  • Humidifiers
