20 Most Recent Cisco 7910 IP Phone Questions & Answers
My cisco ip phone 7960
You can try a couple of things: Unplug the power cable from the phone, hold dows the # key, and then plug the power cable in again. The phone begins its power up cycle. Release the # key after the Speaker button is no longer lit. You should see the following message on the phone: "Reset key sequence detected" Press 123456789*0# within 60 seconds after the Headset, Mute, and Speaker buttons begin to flash. If you enter this key sequence correctly, the phone displays this prompt: Keep network cfg? 1 = yes 2 = no In order to maintain the current network configuration settings for the phone when the phone resets, press 1. In order to reset the network configuration settings when the phone resets, press 2.
Or to perform a full reset: Press **#** to reset the Cisco IP Phone 7960
3/15/2011 2:24:05 PM • Cisco 7910 IP... • Answered on Mar 15, 2011
How to unlock cisco ip
  1. Press **# in order to unlock Network Configuration on the phone.
  2. Press Settings.
  3. Press 3 on the keypad (or scroll down) for Network Configuration.
  4. Press 33 on the keypad (or scroll down) for Erase Configuration.
  5. Press the Yes softkey.
  6. Press the Save softkey.
3/3/2011 7:04:53 AM • Cisco 7910 IP... • Answered on Mar 03, 2011
How can I clear /
How to set a Cisco IP phone to factory default Reset configuration of Cisco IP Phone (7910, 1911, 7940, 7941, 7960, 7961)
To set the Cisco IP phone to factory default completes the following steps: should be completed:
For 7940, 7941, 7960, 7961 phones:
1. Power up the phone (unplug power cable and plug in again and hold the # key.
2. Release # when lights start flashing.
3. Press 123456789*0#.
4. Press 1 to keep network configuration or 2 to lose the network configuration.
For 7906G and 7911G phones:
2. Release # when MWI starts flashing.
3. Press 3491672850*#.
1/11/2011 5:02:04 AM • Cisco 7910 IP... • Answered on Jan 11, 2011
2answers
7910 IP Phone
please check if firewall is ON on your netgear router...
1/13/2010 4:11:30 AM • Cisco 7910 IP... • Answered on Jan 13, 2010
Converting Cisco 7940 IP Phone to SIP
Unlocking a Cisco 7940
Method 1:
1) Unplug the phone
2) Plug the phone back in while holding the # key
The phone will soon display “Reset key sequence detected”
3) After several lights flash press the following keys in order:
1 2 3 4 5 6 7 8 9 * 0 #
4) The phone will then ask you if you want to save the network configurations:
Save network cfg? 1=yes 2=no
5) The phone will soon display “Factory reset initiated” and will continue
through the boot up process.
If that process fails to work for some reason there
is a second method.
Method 2
Complete these steps:
  1. Press Settings.
  2. The Network Configuration lock symbol must be unlocked. If not, exit to the main window and press ** # again.
  4. Press 33 on the keypad (or scroll down) to Erase Configuration.
The phone will now be reset.
Also see this link
http://www.cisco.com/univercd/cc/td/...tain.htm#93250
11/25/2008 5:06:47 PM • Cisco 7910 IP... • Answered on Nov 25, 2008
Cisco ip phoe
Is the phones registered to CallManager or CME?
if CM, then it could be because of partitions and Calling Search Spaces. PTs are placed on the line and are restricted by CSSes. http://cisco.com/en/US/docs/voice_ip_comm/cucm/admin/4_1_3/ccmsys/a03ptcss.html#wp1020642
If it is CME, then it could be a configuration issue
http://cisco.com/en/US/docs/voice_ip_comm/cucme/roadmap/itsph.htm
2/13/2008 11:37:11 PM • Cisco 7910 IP... • Answered on Feb 13, 2008
Cisco IP Phone 7945 booting problems Black screen and Speaker light stays solid green
talk to CISCO on there official forum. real start here https://community.cisco.com/ why go anywhere else. as rules can be fluid , for sure if security gets more tight every day. talk to them , actual
4/3/2022 1:03:22 AM • Cisco Computers... • Answered on Apr 03, 2022
What are the different types of Cisco Firewall which are used these days?
    these are the popular firewall for recent days: ·Packet filtering firewall ·Circuit-level gateway ·Stateful inspection firewall ·Application-level gateway (aka proxy firewall) ·Next-generation firewall
5/28/2020 3:50:46 PM • Cisco Computers... • Answered on May 28, 2020
What are the benefits of various versions introduced in networking Cisco ASA 5580 Firewall?
  • Packet filtering - ...
  • Stateful filtering - ...
  • Routing support - ...
  • Transparent firewall - ...
  • AAA support - ...
  • VPN support - ...
  • Supports IPv6 - ...
  • VPN load Balancing -
5/13/2020 4:17:06 PM • Cisco Computers... • Answered on May 13, 2020
Cisco Router Customer Care Phone {+1^84433O*233O^} numbeR USA
Su mensaje no califica como una pregunta o consulta para un problema, intente en otro lugar NO HAGA ESTE SITIO CON SU BASURA Lleve su BASURA a otro lado Su mensaje califica como SPAM
10/20/2019 6:49:42 AM • Cisco Computers... • Answered on Oct 20, 2019
Cisco Router Customer Service pHoNe #{+1*844~33O233O~} nUmBeR USA
Your message does not qualify as a question or query for a problem, try somewhere else DO NOT MAKE THIS SITE WITH YOUR GARBAGE Take your GARBAGE to another Side Your message qualifies as SPAM
10/19/2019 6:53:00 PM • Cisco Computers... • Answered on Oct 19, 2019
Cisco Router TeCh SuPpoRT Phone nUmBeR @{1*84433O^233O~} USA
10/19/2019 6:52:32 PM • Cisco Computers... • Answered on Oct 19, 2019
Cisco Router Customer SuPpoRT pHoNe @{1*84433O^233O~} nUmBeR USA
ACURTNADA, Your message does not qualify as a question or query for a problem, try somewhere else DO NOT MAKE THIS SITE WITH YOUR GARBAGE Take your GARBAGE to another Side Your message qualifies as SPAM
10/19/2019 6:52:19 PM • Cisco Computers... • Answered on Oct 19, 2019
2answers
Cisco Router Customer Care Phone'@#[+1^84433O*233O-] numbeR USA
Warning SCAM - DO NOT CALL THESE NUMBERS. These phony support numbers send you to criminal call centers where they will install malware, steal ID and/or extort money from you . Please only ever use the support contacts from the official company website
10/19/2019 3:17:29 AM • Cisco Computers... • Answered on Oct 19, 2019
CISCO tech support phone +[@;-{+1'8OO//8O3^1O69}] NuMbEr USA .Anita
10/17/2019 9:36:50 PM • Cisco Computers... • Answered on Oct 17, 2019
Cisco 7910 IP Phone Logo
Popular Tags
15 questions posted
Top Cisco Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Cisco Computers & Internet
Most Popular Question
unlock cisco ip
  • Computers & Internet
