20 Most Recent
DXG Technology DXG-305V Digital Camera Questions & Answers
Download driver free
You don't need a driver.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa (
http://picasa.google.com ).
If you really want the driver, you may download it at
http://www.dxgusa.com/CustomerService/Drivers/DXG305V.exe
The LCD turned Upside down
Try resetting the camera bt removing the battery for 20 mins, then replace the battery and go into the menu and set the Date & time.
Is there a mac driver out there?
I am currently having the same issue with my iMac. My brother loaned me his DXG and can not find the software for it so nothing works. everything I read says there is not compatible driver for mac.
I bought this camcorder at
You can download the driver at
You can download the manual at
http://www.dxgusa.com/CustomerService/Manuals/DXG305VE.pdf
I purchased a DXG model
Copy and paste this address in your browser. It will take you to the pdf of the owner's manual that you can download to your computer.
Want to put pics from
You can download the manual and software from
http://www.dxgusa.com/downloads
You might want to consider NOT connecting your camera to your computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
