20 Most Recent
DXG Technology DXG-308 Digital Camera Questions & Answers
I CAN'T GET THE PICTURES OUT OF MY CAMERA
ALTERNATE WAY TO TRANSFER PHOTOS AND VIDEOS TO A COMPUTER If your photos and videos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos and to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
We need the drivers to
You don't need a driver.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as iPhoto and Windows Photo Gallery.
I can't upload pictures to
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://pciasa.google.com ).
I was given a dxg-308 digital camera without the
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Lost the charger and usb cable where can I buy
Apex Battery offers two DXG-308 chargers
http://tinyurl.com/2fstzxp
laptoptraveler.com has a charger they say is compatible with the DXG-308
http://www.laptoptraveller.com/battery-dxg-dxg-308-digital-camera-accessories.html
You can bypass the need for a USB cable with a card reader. That also saves wear on your camera.
Search Amazon.com for "card reader" and choose one compatible with your memory card
The DXG-308 camera shows a hand and lock when we
The camera displays a
Hand icon indicating that the lighting conditions are dark and where extra-steady shooting is required. (See attached image)
To eliminate this problem, kindly shoot in brighter lighting conditions.
Hope this solves your problem. Thanks for using FixYa.
Camera displays a hand with a lock image and
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
