20 Most Recent Casio Exilim Ex-h30bk Ex-h30 Black Digital Camera 16.1 Mega Pixel Questions & Answers
Exilim camera memory full when few pictures taken
Have you fitted a memory card? The camera will only take a few photos using its own memory. It takes: SD Memory Card, SDHC Memory Card , SDXC Memory Cards. If you have fitted a memory card it may be faulty and you will need to buy another.
9/11/2014 3:56:08 PM • Casio Exilim... • Answered on Sep 11, 2014
When putting SD Card in Casio 300TV data slot to format it, it shows 'err format'. How to solve the problem?
This nearly always happens because an SD card is used that is FAR too BIG for the unit. 1 GB or LESS it says in the manual. G Supported Memory Cards: SD memory cards, optional CASIO song data cards* G Supported SD Cards: 1 GB or less (Cards with capacity greater than 1 GB are not supported.) G Maximum Number of Importable Songs: Up to 1,000 • The actual number of songs that can be imported depends on the size of each file. The actual number will be less than 1,000 when individual song files are large. G Supported Data: SMF Format 0, CASIO Original Format CM2 Manual at the page 54 (E52). https://www.manualslib.com/manual/26181/Casio-Lk-300tv.html?page=54 ..
12/19/2022 11:19:47 PM • Casio Cameras • Answered on Dec 19, 2022
2answers
I have a Casio exiling EX-Z1000 and all of a sudden the screen stays blank when the camera is turned on when I have gone through set up all I get is there are no files
Hi, please check that your camera has a properly working Sd card. If the SD card is potentially damaged, then you would not be able to view the damaged contents on the camera. Please take a few test photos and see if the display photos returns. If not, then it might be time for a factory reset. Thank you.
11/22/2022 4:59:19 PM • Casio Cameras • Answered on Nov 22, 2022
Lens stuck halfway out Casio Exilim July 20 2009
Question edited for all the typos. Question moved from Casio computer to Casio Camera. If you are reading something back in 2009 make sure you aren't reading 'Suggested Answers' as they are often not the item you have. It also sounds like you are giving a testimonial as a new post to someone that is no longer on the Fixya site? This is your only post, did you fix your camera? https://www.fixya.com/users/rachel-evans-25235 ..
4/1/2022 4:41:34 AM • Casio Cameras • Answered on Apr 01, 2022
2answers
How do I set the time on a Casio AQ-230 watch?
Have you considered following the explicit instructions which will be contained in the manual ?
1/26/2022 2:08:10 AM • Casio Cameras • Answered on Jan 26, 2022
2answers
We have a casio exilim
buy a new battery (DUH)
12/3/2021 1:00:41 AM • Casio Cameras • Answered on Dec 03, 2021
Casio exilim ex-z850, won't power
sounds like dirty battery contacts to me
12/2/2021 7:30:11 PM • Casio Cameras • Answered on Dec 02, 2021
My Casio XJ-M255 lights are red, what can I do to fix this problem?
For checking out the problems related to your Casio XJ-M255, I will suggest you check out the manual or download it and look at page 19 of the manual, all will become clear.
12/2/2020 3:23:18 PM • Casio Cameras • Answered on Dec 02, 2020
Model XJ-M255. Why are lights red?
A) This is not a camera. B) If you look at page 19 of the manual, all will become clear.
11/2/2020 10:45:25 PM • Casio Cameras • Answered on Nov 02, 2020
Menu key is not functioning in casio exilim EX-270
the solinoid switch may be n/working, apply contact cleaner beneath the menu butten
1/7/2020 9:33:54 PM • Casio Cameras • Answered on Jan 07, 2020
2answers
Just need to know how to download camera to my
Find free how to download xmeye for pc a free software for remote video surveillance. Get more information at http://SoftLister.com
1/6/2019 2:20:59 PM • Casio Cameras • Answered on Jan 06, 2019
Casio Exilim lens does not open after fall . Why?
Because it is damaged, broken or otherwise rendered incapable of functioning. It needs repairing.
12/31/2018 7:29:18 PM • Casio Cameras • Answered on Dec 31, 2018
My Casio 2879 has the message “3sec” for some reason......how do I delete it?
Go delayed photo mode and remove it.
7/17/2018 11:31:32 PM • Casio Cameras • Answered on Jul 17, 2018
Casio Exilim EX-P700. when we insert the SD or MicroSD cards the camera powers off.
NEVER remove or insert a memory card while the camera is powered up. The camera is probably shutting itself off to avoid damaging the data on the card.
4/13/2018 10:00:42 PM • Casio Cameras • Answered on Apr 13, 2018
2answers
My view finder is really blurry, how can I fix this on my casio exilim ex-s8
Some cameras have a small dial near the viewfinder to correct for your vision or if you wear glasses. Look for that.
12/14/2017 2:54:56 PM • Casio Cameras • Answered on Dec 14, 2017
Hi I have a casio exilim ex-s8 and my view finder is extremely out of focus and blurry, how do I fix this?
Look in the manual for an entry under dioptre correction, or eyepiece adjustment.
12/12/2017 9:17:27 PM • Casio Cameras • Answered on Dec 12, 2017
Casio Exilim 5.0 mega pixels
Hi - sorry but this is a very old camera - nice in its day (I had one) but now so out of date. Any camera which extends the lens is prone to disaster if the lens is knocked when extended - you don't need a grandson to do that either. Any slight fall will knock the lens out of alignment - each sections runs in a very fine twisting in/out circular track as they move - a knock will move all or part out of its track. Sometime you can be lucky and press (straighten) the lens so that its back in alignment - mostly not tho. Given its age, and the vastly improved cameras out there now at far cheaper prices that we paid 12-15 years ago, suggest you remove the memory card and battery, and give him the camera to play with!. Go get yourself a replacement - if you want a camera which does not extend the lens, that will sit flat in your pocket/purse, even when on, consider the likes (or similar) of the Sony Cybershot DSC-TX55. - great camera - (more like a powder compact as the lens does not extend.) I have one can so can recommend. Other brands have similar 'flat' cameras also. Save more dollars - find a nice secondhand one on ebay or similar. To use, all you do is sllde the front plate down and you are off. Cheers - have fun taking pics of that g/son. Mike
12/11/2017 3:46:03 PM • Casio Cameras • Answered on Dec 11, 2017
Casio Exilim Ex-h30bk Ex-h30 Black Digital Camera 16.1 Mega Pixel Logo
1 questions posted
Top Casio Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Bill Eager
Are you a Casio Camera Expert? Answer questions, earn points and help others
View Most Popular
Casio Cameras
  • Casio Cameras
Most Popular Question
exilim camera memory full when few
  • Cameras
