20 Most Recent
RCA (DVDCP33) Media Questions & Answers
Pearl won't turn on
I press on the menu to start the device and it show's PEARL but won't go past that. I've taken the battery out and put fresh batteries in and it remains on that until the batteries died and then I put new battery in and it did the same. It won't go past the loading image and the computer say's to check the device, but from what I can tell, nothings wrong
WHAT DOES iddataaai CODE MEAN
My Philips MP3 player had the same problem after I saved some non-music
files onto it through USB connection. After I deleted these files, it
seems to be working okay again. If it doesn't work, I guess you can
also try re-formating it.
My MP3 Player
well i think there is some charging discharging problem ,go for repair!!!try and update its software see if it works oderwise repair is the only option!!
Mp3 player isn't working
when i turn on my mp3 it just satys at the company name MAGNAVOX and yester it said MEMORY FULL!!! is that the problem??
Only plays 6 songs on it!
How do you have the settings for playback? Is it on random, artist or album? Check those settings. Maybe something got changed by accident.
Kingston DTI/512
If you are unable to open it ,there might be a virus in you flash drive which is causing problem .
Solution:
Select the flash drive and right click .now select autoplay, a dialogue box will appear ,now select open to open it..
if you are unable to do this .
open my computer ,in the address bar ,click on the downn area button in address bar and select flash drive to open .if this also fails you have to format the flash drive ..
Try this in other pc if you are unable to do this on your computer ..now if you are getting same problem ,format it.
right click on it >select format >and format it to remove virus ...
If this answers your question please rate this as fixed.
THANKS.
Mp3 player problem
Maybe you ran put of space so it would have automaticaly deleted some songs....
