20 Most Recent
Ricoh Aficio 180 Laser Printer Questions & Answers
Error Message SC320
We are buying a new machine! The price of the motor and labor is more than the machine is worth.
I need solution to aficio 200 error code sc322
sc322 is a Laser synchronization error:
Means that the laser synchronization signal cannot be detected by the main scan detector board.
Possible causes:
Poor
connection of the interface harness which connects the
laser synchronization detector board and the
BiCU board.
Laser synchronization detector board out of position or is defective.
BiCU board is defective.
Unfortunately,unit needs service.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at
https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Sc320
That is a "Laser motor" Error - Laser motor is dead, and needs replacement
Aficio 180 error sc500
Main motor/ transport motor lock/ fusting motor error.
sc
500 is main motor lock.it happens bcoz of mainly 2 reasons .first main
motor faulty.second main motor is not able to take the load tat means
cam gear is jammed or broken.
The only thing you can do is check for any obstructions in the machine.
That needs to be looked at by a service because the problem could be a motor, a pcb, or a power supply.
It can be a lot of troubleshooting to do.If you need a manual to consult and do not have it you may get it here
http://safemanuals.com/314159.php?k=3cac4a393ecf714c6904fc8065e85db2Regards.....
I have a Savin 9945dpe copy/printer that is
Oh wow, I bet it occurred when you vacuumed the machine. You never want to run a vacuum inside of electronics due to all the static energy it creates. You need a very special kind of vacuum to do that. The only thing you can try is to turn off the machine with the power button, then to unplug it for a good 2 minutes. Then replug in the machine and try firing it up. Hopefully it will reset whatever was tripped inside by the static electricity. If it still has the error message you need to contact Savin to find out about a repair at:
1-800-524-1801 or just visit their website here and find an authorized person to help you:
http://www.savin.com/global/DealerLocator.aspx
How to reset toner on Ricoh Aficio 180
If you want to reset the toner bottle, open the front cover, lift up on the green toner handle, push the lever in to slide out the toner hopper, pull out the toner bottle, give it 1 or 2 gentle shakes, and put it back in the hopper. Then push the hopper closed until it snaps into place, push the handle back down, and close the front door.
