20 Most Recent
Samsung SF 5100 Laser Printer Questions & Answers
Can i use sf 5100
SF 5100 is a good printer you can use it and if you face any issues you can contact us but I am sure it will not bother you
This version of the file
It sounds like you are using the cd that came with the printer on a Windows 7 PC. Just plug in the usb cable and Windows 7 should install a generic driver for your 5100. If it asks for a disk then there is no Windows 7 driver and you will not be able to print to this fax.
Need to download
http://www.samsung.com/in/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=1703&prd_mdl_cd=SF-5100PI%2FTED&prd_mdl_name=SF-5100P&srchword=SF-5100P
Double page copies and CRU Error
CRU Fuse error equates to a problem the machine has reading the print cartridge installed in the machine. It has nothing to do with the fuser.
Suggest that you change the print cartridge.
My samsung
I need fuser error solution as soon as possible please.
Hpofficejet: will not receive
I just got a new line just for my SF-5100 fax. It was working before I switched to this phone company. I checked the line on a regular phone and it seemed ok. When I plug it up to my fax machine, when it rings I get this static sound instead of rings. One of my customers said when she tried to fax something, she got that same static sound and it would not go through. When I tried to fax her something, I dialed the number and when the fax machine was repeating the numbers it was a series of that same static sound. Then the operator said I should try my call again - so it did not dial through. A few minutes ago, the screen said RX also. Can you please help?
Replace cartridge message after new cartridge installed
If the cartridge you are installing is a refilled/remanufactured cartridge it may be that you need to indicate to the printer that it is a used cartridge and not a new one upon installation. This is because the cartridge works on a basis of counting pages and calculating page coverage to estimate how full it is. It has no way of telling that it has been refilled and can indicate to the printer that it is running low and needs replacing.This message could however be the result of something as simple as the printer not being able to recognise the cartridge. In which case I would recommend wiping the contacts on the cartridge with a piece of kitchen tissue and re-installing. if this fails to helps I would recommend replacing the ink cartridge.
