20 Most Recent
Samsung (MP0804H) 80 GB Hard Drive Questions & Answers
HDD is not detect &
I f ur hearing a whirling and clicking noise in ur HDD, that means it is already BUSTED and needs to replace!
The internal LENS can't read the disk anymore!
Taah!
5/1/2013 4:45:01 PM •
Samsung...
Answered
on May 01, 2013
My Samsung MP0804H HD is
click start control panel scroll to folder options this may vary depending on your operating system place a tick in the single click to open a folder option or if you right click on the drive/folder select properties there will be an array of options in the security tab make sure you have full control
click start control
panel user accounts on the users tab,click the name of the computer
administrator you must have full control be the computers "administrator"
hope this helps
4/17/2011 2:10:47 PM •
Samsung...
Answered
on Apr 17, 2011
How to slave hard drive?
To configure the hard drive as a slave drive, you need to set a jumper on the hard drive to SL (slave)
The other jumper settings are MA (master) and CS (cable select).
3/19/2011 1:16:39 AM •
Samsung...
Answered
on Mar 19, 2011
Not formating
What sort of drive is it? - IDE, EIDE, SATA, SCSI etc - what are you using to try to format it?
What operating System are you using?
2/15/2011 6:14:35 AM •
Samsung...
Answered
on Feb 15, 2011
I want to replacement of
You do NOT need to buy a new Samsung disk-drive.
You can buy a replacement from Western Digital, or from Seagate/Maxtor, or any other manufacturer.
Take your current Samsung disk-drive to the computer-store, so that they can sell you a new disk-drive with IDENTICAL data/power connectors (either Parallel-ATA or SATA).
2/1/2011 4:40:36 PM •
Samsung...
Answered
on Feb 01, 2011
Samsung Hard Disk MP0804H
maybe your HDD are not compatible in your laptop. try to look it in your manual if it is compatible or not.
12/17/2010 6:30:15 AM •
Samsung...
Answered
on Dec 17, 2010
HDD PROBLEM
you have not listed the problem so i guess
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
hope this helps
12/11/2010 7:47:11 AM •
Samsung...
Answered
on Dec 11, 2010
Hdd not detected
It's probably out-of-warranty. It's time to replace it.
10/26/2010 3:14:08 PM •
Samsung...
Answered
on Oct 26, 2010
I have 1 80 gb
good day,
try to reformat you hard disk,. if its a physical defect then there is no way you can fix it.
on the other hand, if you are familiar with RMA, then you could send the defective Hard disk that you have to the Manufacturer and they will replace it brand new...
9/24/2010 8:05:56 AM •
Samsung...
Answered
on Sep 24, 2010
I want to know that
Just visit the shop where you have purchased your pc or just try out the bill when u purchased they mention how many they provided warranty
8/20/2010 9:13:19 AM •
Samsung...
Answered
on Aug 20, 2010
My samsung harddisk is so
Hello their sam4ubabe
So you mean you Took it off and put it back again...
Try this sequence:..
1. Remove your Hard disk
2. Clean it, remove Dust particles around the connectors
3. Put back the Hard disk, don't tight it so much.
4. Put back those Connectors from Hard disk connectors and Power Connectors.
5. Push the connectors to tighten contacts.
Power it ON.
Lets see if it goes back.
-dontput
8/17/2010 9:05:05 AM •
Samsung...
Answered
on Aug 17, 2010
