1) Do the voltage values stay the same right before the shutdown, or do they drop?
2) Plus, Voltage values; Are you getting a full 3.3 Volts, 5 Volts, and 12 Volts?
3) Check the Electrolytic Capacitors on the motherboard for visual signs of failure.
A) Electrolytic Capacitors are used on the motherboard as Filters, or Voltage Regulators, (Motherboard voltage regulator circuit)
B) Computer designers know that Electrolytic Capacitors break down over time. This is why they use capacitors that are rated at 50 percent more than is needed. When the capacitor (Electrolytic) breaks down to the 50 percent level, it is still good enough.
C) The Electrolytic Capacitors used on the motherboard are Radial Aluminum Electrolytic Capacitors.
Basic construction of a R.A.E.C. is;
1) A cylindrical aluminum case shaped like a Coca-Cola can, but with no top, or bottom
2) Top seal is a Vent Cover. A flat round thin disk composed of Aluminum, that has a shape etched partway into it, in the middle. Usually a K or X.
3) Bottom seal is a Bung. A flat round thin disk composed of synthetic rubber.
4) Three strips.
A) One strip is metal tinfoil composed of Aluminum.
B) One strip is also aluminum tinfoil, but has a non-conducting medium applied to it.
C) One strip is a paper-like strip that is soaked with Electrolytic Paste.
Strip A is the Conducting strip. It has the Positive lead, (Think wire) attached to it.
Strip B is the Non-Conducting strip. It has the Negative lead attached to it.
Strip C is placed in-between Strip A and B, and all three are rolled up tightly.
The Positive lead, and Negative lead, poke down through the Bung at the bottom of the capacitor.
When the capacitor starts to fail a gas is developed inside. (Hydrogen Gas) The paste breaks down, and makes the gas.
The gas expands, and breaks the top Vent Cover open at the K or X, AND/OR, pushes one side edge of the Bung out.
The gas then slowly pushes the Electrolytic Paste out. (It oozes out)
So much paste loss, and the capacitor operates at a weakened state.
Too much paste loss, and the capacitor fails.
The paste can also dry up inside, and show no visual outward signs of failure.
http://www.capacitorlab.com/visible-failures/index.htmPower unplugged to computer, Anti-Static Precautions observed, the motherboard should be removed for visual inspection of the capacitors.
It may require using a magnifying glass, and a good light.
Post back in a Comment as to your findings.
Regards,
joecoolvette
http://www.hardwaresecrets.com/article/616
