20 Most Recent
Shuttle AB60N 865PE Motherboard Questions & Answers
Keyboard not response
laptop or desktoptry blowing out all of the dust from your keyboard using a fine air blower from an air compressor making VERY sure there is no MOISTURE in the lines.
dust causes static which causes lots of problems with a computer and its parts
you might have to uninstall your keyboard restart your computer then reinstall it
make sure the lead connection is secure and dust free (if applicable)
make sure the usb device is inserted correctly into the usb port (if applicable)
click start control panel administration tools computer management device manager scroll to keyboards also mouse you might see a yellow exclamation or question mark ! ? or red x you will need to update driver right click to update driver
if your computer came with a motherboard disk the drivers could be on it
hope this helps you
Repair ashuttle 250 psu
If the "250" is referring to the PSU's wattage, I think we have found the problem. Please purchase a 500 watt or higher PSU with a 80 percent silver or higher rating and you will be back up and running, that is if the motherboard is indeed good.
4/7/2015 9:02:32 PM •
Shuttle...
Answered
on Apr 07, 2015
