20 Most Recent
Panasonic TH-L42U20S Full HD 42 inch Multi-System LCD TV Questions & Answers
Suport format mpeg4,flv,..
Please never do any more experiments with software [firmware] with this set. Contact the authorized service centre for Panasonic. If you wish to get some details; check the site linked here. Viewing it in "
Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
3/24/2014 5:50:10 PM •
Panasonic...
Answered
on Mar 24, 2014
Random Side Panel Inputs
You either have a bad Main board or simply a bad touch control button in other word one of your side buttons is defective and it is blocking any other signal to the main board, but usually its a bad main board. In some cases ther is a FIRMWARE update from Panasonic, you may want to call Panasonic or check there website for any type of FIRMWArE UPDATE.
Panasonic TC-L32X1 The picture blinks on and off but it still has power
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. Check the site in '
Mosaic' view. It will make search easy.
