20 Most Recent
RIM BlackBerry 7100v Handheld Questions & Answers
What is auto on/off for
That feature is for holstering your BB. When you holster it, it will go into auto off mode, and when you take it out of the holster, it will auto on.
M not able 2 make or recive calls on my blackberry
Try this: First, download and install the latest version of BlackBerry Desktop Manager software from: https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=DA5FB46338C8C0DCB1039F7898184FC5
Once installed, connect your BlackBerry to your computer via the USB sync cable. Open Desktop Manager, and click the Application Loader. On the right, you will see Update your device software. Click the Start Button, and if your BlackBerry is not on the latest Handheld Software, an update will appear. Select the update, and run the install. Be sure to select the option that backs up and restores your data. Once started, do not shut down your computer, or disconnect the USB sync cable as this could damage the device.
Once completed, your BlackBerry will restart and you will have the latest version available. This version has been known to correct various issues.
Hands Free for 7100v
blackberry phones need to be paired via bluetooth, with the car running search for devices with your phone and it should find the cradle, pair using passcode 1234. hope this helps, dan.
Unlock sim
You want to unlock the phone.... not the sim....
In another country, you will most likely get a new sim card frrom a local carrier for the unlock exercise to be worth while.
http://www.unlockitnow.com/Blackberry http://www.unlockanyblackberry.com/
Hope that helps.. :)
