20 Most Recent
Lexmark "x4650 multifunction inkjet printer" Questions & Answers
Ca no longer scan or copy
Try to unplug the power adapter at the back of the printer for about 30 seconds then plug it back in.If it doesn't work, then the printer may already be defective.
Good afternoon. My Lexmark 792 printer shows error 956.02 at startup when adjusting colors, how can I solve it?
The 956.02 error on your Lexmark 792 printer indicates a system board issue. Troubleshoot it step by step:
Power off the printer: Turn off the printer and allow it to remain powered off for 10 to 20 seconds before turning it back on.
Check the code level:
You can identify the current code level using either of the following methods:
Method 1: Print the Menu Settings Page:
Touch the Menu button on the printer's operator panel.
Select Reports.
Choose Menu Settings Page to print the page.
Look for the code level under Device Information.
Method 2: Use the Printer's Embedded Web Server (EWS):
Open a web browser (such as Internet Explorer) and enter the printer's IP address.
Click on Reports and then select Device Information.
Download and install the latest firmware:
If your printer's code level matches any of the following:
For C792: LHS1.HC.P129 or LHS1.HC.P130
For X792: LHS1.MR.P131, LHS1.MR.P135, or LHS1.MR.P135a
For X925: LHS1.HK.P136a
Proceed to download and install the latest firmware.
For C792: LHS1.HC.P131 or later
For X792: LHS1.MR.P135b or later
For X925: LHS1.HK.P136b or later
Contact Lexmark Technical Support for service.
Update the firmware:
Download the latest firmware from the Lexmark Support website.
Save the file and extract it to the same directory.
Use the appropriate Authorization Keycode:
For Lexmark C792: c792
For Lexmark X792: x792
For Lexmark X925: x925
Update the firmware using one of the following methods:
Embedded Web Server (EWS): Open a browser, enter the printer's IP address, and select Settings > Update Firmware.
USB utility: Follow the detailed steps for updating via USB flash utility.
USB thumb drive: Refer to the steps for updating using a USB thumb or flash drive.
FTP: Follow the steps for updating via FTP.
If you need further assistance, please contact Lexmark Technical Support. When calling, have your machine/model type and serial number (SN) ready.
956.01 system board error ' Lexmark C792
Error Codes > Lexmark > X792dtse > Code 956.02 (printcopy.info)
What can replace the ibm lexmark wheelwriter 1000
If you're looking for a replacement for the IBM Lexmark Wheelwriter 1000, you might consider a typewriter like the Brother M-1000, the Olivetti Studio 45, or the Smith Corona SR8000. These typewriters have similar features and capabilities to the Lexmark 1000, and they're often considered to be good alternatives.
My computer guy just installed Lexus Mint on my computer and downloaded the proper driver for Pantum 7100 series printer
How do you 'install' Lexus Mint green on your computer?
https://www.google.com/search?q=Lexus+Mint
Driver
PANTUM
https://global.pantum.com > support > download > dri...
Home Service&Support Driver/File Download Driver ... printer. Product Series. Product Name. You may need. Pantum P2500 Windows Driver. Version: V2.6.30.
PANTUM M7100DW Printer Driver Download
trikprinter.com
https://www.trikprinter.com > PANTUM
Apr 8, 2017 - Install Driver For Printer. Install Print Driver For Windows : Download the file. select the location of the file that is already stored. Double ...
Drivers for printers Pantum M6700 / M6800 / M7100 / ...
DriverFresh.com
https://driverfresh.com > DF.com > Printers and MFPs
Drivers for printers Pantum M6700 / M6800 / M7100 / M7200-series for Windows 11 - XP (32/64-bit), Mac OS X 12 - 10.5, Linux Ubuntu 20.04 - 12.04 in English.
how do I publish a printer [duplicate]
Ask Ubuntu
https://askubuntu.com > questions > how-do-i-publish-...
Jan 5, 2013 ยท 1 answer
Open the dash and type Printers, then click on the "Printers" icon. That will open up a window that will probably have a list of printers.
What is CUPS server and how to share a printer ...
Oct 28, 2011
HPLIP or CUPS cannot Find Network Printers?
Jan 25, 2013
More results from askubuntu.com
Deploying Printers to Domain Users and Computers with ...
Windows OS Hub
https://woshub.com > Group Policies
Nov 8, 2022 - You can publish your shared printers in Active Directory. To do this, enable the List in the Directory option in the printer settings on the ...
Use Group Policy settings to control printers
Microsoft Learn
https://learn.microsoft.com > ... > Windows Server
Feb 23, 2023 - Describes the policies specific to managing printers and how to enable or disable printer management by using the Local Group Policy Editor.
Need drivers for Lexmark 4431
- Visit the Lexmark Support Website: Go to the official Lexmark website (www.lexmark.com) and navigate to the "Support" or "Downloads" section.
- Enter Printer Model: In the search or product support area, type "Lexmark 4431" or the full printer model number (e.g., "Lexmark 4431-001") and hit Enter or click the search button.
Lexmark cs 410dn EN E4 16 error
The "E4 16" error message on a Lexmark CS410dn printer indicates that there is a problem with the printer's toner cartridge. This can be caused by a variety of issues, such as:
- The toner cartridge is not properly installed in the printer.
- The toner cartridge is not compatible with the printer.
- The toner cartridge has reached the end of its useful life and needs to be replaced.
- The printer's firmware is out of date and needs to be updated.
To resolve the issue, you should try the following steps:
- Turn off the printer and unplug it from the power outlet.
- Open the printer's front cover and ensure the toner cartridge is properly installed.
- Clean the electrical contacts on the toner cartridge and the printer with a dry, lint-free cloth.
- Reinstall the toner cartridge in the printer, being careful to align it properly.
- Turn on the printer and check if the error message is cleared.
If the error message persists, you may need to check the compatibility of the toner cartridge with your printer model, and the age of the cartridge. If the cartridge is old, you might need to replace it with a new one.
Updating the firmware of the printer can also solve the problem, check the Lexmark website for update on the same.
In case the problem persists after trying all the above troubleshoot, please contact Lexmark support for further assistance.
Lexmark c935 error video making
If you have replaced the engine board on your Lexmark C935 printer and are still experiencing an error 905.01, there could be a few other possible issues that may be causing the problem. Here are a few things you can try to troubleshoot the issue:
- Check the printer's firmware: Make sure the printer's firmware is up to date. If the firmware is out of date, it can cause errors like 905.01. You can check for updates on the Lexmark website or by contacting Lexmark customer support.
- Check for any visible issues: Inspect the printer and its components for any visible issues that may be causing the error. This can include debris or foreign objects that may have gotten stuck in the printer, or damage to the printer or its components.
- Check for other issues: If you have checked the firmware and there are no visible issues with the printer, it is possible that there is another issue causing the error. You may need to have the printer serviced by a professional to diagnose and fix the problem.
I hope this information is helpful. If you have any further questions or need additional assistance, please don't hesitate to ask.
Lexmark MS811N Printing only blank pages
Please remove the toner/ink cartridge out and shake it 4 or 5 times before placing it back into your printer and testing a few prints. Lexmark also recommends checking for packing material on the imaging unit.
Thank you.
