20 Most Recent
HP Officejet 4500 Wireless All-in-One Inkjet Printer with Copy/Fax/Print/ Questions & Answers
My hp 4500 officejet wireless printer prints horizontal bands
Are you using original HP ink cartridges or refilled ink? If it is original HP ink then the evidence points towards the printhead failure.
However, I recommend you to perform the following steps to isolate the issue and arrive at a fix:
NOTE: Please skip any steps that you might have performed already.
Disconnect the power cable from the printer while the printer is still ON.
Disconnect any other cables if connected the printer.
Press and hold the printer's power button for 15 seconds.
The printer should be directly connected to the wall outlet and not to a surge protector.
Reconnect the power cable to print and the printer should power ON by itself. If the printer doesn't power ON then please manually power it ON.
If the error persists then please perform a firmware update on the printer via this link.Please restart the printer once after the firmware update.
If the issue persists then I suggest to reset the printer. Resetting the printer restores the printer to its original factory settings. I have sent you a private message with the steps to reset the printer.
HP OfficeJet 4500 drivers for Windows 10
To install Drivers for printer and scanner of Hewlett-Packard Officejet 4500 same as G510 don't try to install it on Windows 10. You may found that. So what to do.
find in main HDD c: programfiles x86 hp and delete. (check if you have other hp machines so be careful) .download free program auslogics registry cleaner or with regedit in cmd command and find and delete all entries.
now for example you have the hp officejet 4500 wireless and you have download the OJ_AIO_4500_G510n-z_Full_Win_WW_140_408-5 . find it in the folder and with free 7zip or other like winzip extract it in a folder.
go to printers and add printer. When Win asks for drivers guide the request in extracted folder with checked the subdirectories.
That's it.
Have Fun and make a pray for me.
Nick.P.
The paper is jammed
If paper is jammed and you can't take it out, don't force it. You may damage your printer, Take it to a repair service, they know how to dismount it and remove obstruction without dmamage.
