20 Most Recent
Nikon Coolpix L120 Digital Camera 14.1mp 21x black 26253 Questions & Answers
My mother in law has a cool pix L120. How does she transfer photos from the cameras internal memory to a SIM card?
The only time the camera puts images on INTERNAL memory is when you do not have a SD card in the camera.
When I have an SD in my Coolpix camera and I want to get the images on my computer I take OUT the SD card and put it in the slot in my computer.
The only way to access images ON the camera's internal memory is to have the Computer access the camera via USB. You should be able to see the camera when you plug it in via USB you can copy images from the camera.
You can copy all of the images on the camera to a folder on your computer.
If you can read the SD card on the computer you can copy the images from your computer (folder you made) to the PROPER FOLDER on the SD card. The proper folder is a XXXNIKON Named folder. (I am assuming you took at least one IMAGE with the SD card in the camera.
Nikon L120 shutter release button has to be depressed very hard to work
There is a known design issue with the shutter release switch on the L120. They start to fail after about 1500 shots have been taken. The cause apparently is oxide build-up between the contacts, even though the switch is a sealed unit. The \'half cock\' works fine, but the shutter release requires considerable pressure to take the shot. It gradually gets worse until it eventually stops working altogether. There is presently no known solution since the switch is a sealed unit, and is soldered to the internal circuits of the camera. A spare switch is not available on its own- so the entire internal electronics need to be changed. The replacement part will also fail after the same number of shots have been taken (if you are unlucky), since the same component is still in use.Solution is to get a new camera. Sad, but true since it is not cost effective to repair.
How to recover deleted photos
Want to
restore nikon coolpix l120 image files? Yes dont worry it becomes easy by using JPEG recovery software. This software helps you to recover photos from lost from various storage device like hard drives, USB externals drives, iPods etc.You can download the free demo version of this software and you can recover lost images from nikon coolpix l120.
Photos disappear
Recuva (pronounced "recover")is a freeware Windows utility to restore files that have been accidentallydeleted from your computer. This includes files emptied from the Recycle bin aswell as images and other files that have been deleted by user error fromdigital camera memory cards or MP3 players. It will even bring back files thathave been deleted from your iPod, or by bugs, crashes and viruses!
- Put the memory card into an USB card reader and plug it into the USB port in your computer, then run the Recuva program.
- Simple to use interface - just click 'Scan' and choose the files you want to recover
- Easy to use filter for results based on file name/type
- Simple Windows like interface with List and Tree view
- Can be run from a USB thumb drive
- Restores all types of files, office documents, images, video, music, email, anything.
- Supports FAT12, FAT16, FAT32, exFAT, NTFS, NTFS5 , NTFS + EFS file systems
- Restores files from removable media (SmartMedia, Secure Digital, MemoryStick, Digital cameras, Floppy disks, Jazz Disks, Sony Memory Sticks, Compact Flash cards, Smart Media Cards, Secure Digital Cards, etc.)
- Restores files from external ZIP drives, Firewire and USB Hard drives
- It's fast, tiny and takes seconds to run!
Go to these WEB sites to down Recuva
http://download.cnet.com/Recuva/3000-2242_4-10753287.htmlwww.filehippo.com/download_recuva
Can this be fixed?
Buy a WD40 liquid thine silicon spay and then open the camera body. Now spray the solution on the circuit board & batter connector. Clean them by dry clean cotton. Don't use spray on lens. After that fix the camera and then insert the new battery and see the result.
Lens hood
Apparently the lens hood is too narrow for the current focal length. Either zoom in to narrow the field of view or remove the lens hood.
Just bought Nikon p600 and cant connect to WiFi help
U need to download nikon wmu software from google playstore or appstore. Then start wifi of ur camera and then start wifi connection in ur mobile.select "nikon p600" in wifi setup.when connected, start application named "wmu" in ur mobile.wait for the connection.after few seconds wifi connection will be established.hope this would help u!
