20 Most Recent
Sharp FO-2081 Fax Machine Questions & Answers
System lock of my projector sharp 50s ,so how to unlock?
- Check the Remote: Make sure you have the remote control for the projector.
- Press the Menu Button: On the remote, press the "Menu" button.
- Navigate to Security or System Lock: Use the arrow keys on the remote to navigate through the menu options. Look for a section related to "Security" or "System Lock."
- Enter the Unlock Code: If you previously set a system lock code, you will need to enter it using the remote control. If you haven't set a code before, try the default code (often 0000 or 1234).
- Disable System Lock: Once you've entered the correct code, navigate to the option to disable or unlock the system lock.
- Confirm: Follow the on-screen instructions to confirm your choice, and the system lock should be disabled.
Sharp EL-1197PIII printing nonsense after a jam.
Reset the calculator: Locate the reset button on the bottom or in the battery compartment and press it .
Clean the printer head: Use a soft, dry cloth to clean the printer head and ensure that there is no debris or paper stuck in the printer mechanism .
you are looking for resources to properly align the gears. I found a few resources that might be helpful:
Sharp EL-1197PIII Operation Manual: This manual provides detailed instructions on how to operate and maintain your calculator, including how to align the gears. You can download the manual from the following link:
SHARP EL-1197PIII OPERATION MANUAL Pdf Download ' ManualsLib.
Sharp EL-1197PIII User Manual: This manual also provides instructions on how to align the gears of your calculator. You can access the manual online from the following link:
Sharp EL-1197PIII User Manual online (mans.io).
Sharp EL1197PIII Heavy Duty Color Printing Calculator User Manual: This manual provides instructions on how to align the gears of your calculator. You can download the manual from the following link:
User Manual Sharp EL1197PIII Heavy Duty Color Printing Calc ' manualsFile.
