20 Most Recent
Roku 2 HD Questions & Answers
I'm not able to activate the new code for using PBS. What I done wrong?
We offer complete help for your primevideo.com/mytv device. From the underlying purpose of initiating your gadget till where your channels are flawlessly spilling, we provide step by step assistance. You may have inquiries on initiating the gadget and setting up with all the most loved channels and putting it up inside and out; Prime video helpline has all the orders to sift through all the inquiry you have. We assist with fixing your myTV gadgets, be it initiating it or becoming acquainted with about the Channel list on Roku or in any event, repairing your Roku remote. If you facing any queries related to prime video or mytv, Roku or Android devices setup contact us, our expert's team always available customer help.
More info join us :-http://os4primevideo.com/mytv.html
5/29/2020 7:57:37 AM •
Roku 2 HD
Answered
on May 29, 2020
What is error 011 ?
Your router probably has a firewall turned on turn it off to set up the Roku.
1/11/2015 6:00:09 AM •
Roku 2 HD
Answered
on Jan 11, 2015
I am having difficulty hooking up my old VCR to a TCL Roku TV.
Check the shielding of your antenna. Moreover make distance between VCR and antenna cable. In fact VCRs have a built in modulator and its signal is strong as compared to local antenna signal. There is another way, connect the local antenna in VCR RF In and connect RF Out of VCR to TV. In this scenario you have to tune your VCR to get the antenna channels instead of TV. It will solve your problem.
50 in onn roku tv piocture problem
Hi Randy, it sounds like you have a timing control board from another model or series TV, they can look identical but have different programs in the processor IC, if this isn't the case then something was changed in the service menu while the set wasn't operational. We've seen it happen in our repair center, we replace a board with the correct part but the picture is upside down or reversed, had to have happened when the owner was pushing buttons without a picture on the screen
Lost the remote and need to connect to new wifi
If your Simpson Aquarius 824 washing machine is not spinning, there are a few potential causes for this issue:
- Drive belt: The drive belt that connects the motor to the drum may be worn out or broken. If the belt is loose, damaged, or slipping, it can prevent the drum from spinning. Inspect the drive belt for any signs of wear, damage, or slackness. If necessary, replace the drive belt with a new one. Refer to the user manual or contact Simpson customer support for guidance on accessing and replacing the drive belt on your specific model.
- Motor coupler: The motor coupler is a component that connects the motor to the drum. Over time, the coupler can wear out or break, resulting in no spinning action. Inspect the motor coupler for any signs of damage or wear. If it appears damaged, it will need to be replaced. It's recommended to consult the user manual or contact Simpson customer support for instructions on how to access and replace the motor coupler.
- Lid switch or door lock: Washing machines often have a safety feature that prevents spinning if the lid or door is not properly closed. Check if the lid or door is securely closed and make sure the lid switch or door lock mechanism is functioning correctly. If the switch or lock is faulty, it may need to be repaired or replaced.
- Motor or motor control board: If the motor or motor control board is malfunctioning, it can prevent the drum from spinning. In this case, professional repair or replacement of the motor or control board may be necessary. It's advisable to contact Simpson customer support or a qualified appliance repair technician for further diagnosis and assistance.
Remember to refer to the user manual for your specific Simpson Aquarius 824 model for detailed instructions and diagrams. If you're unsure or uncomfortable performing any repairs yourself, it's recommended to seek professional help to ensure safe and proper repairs.
Bytecc 4K2K LPCM 7.1 Extractor
It appears that the Bytecc 4K2K LPCM 7.1 Extractor may not be fully compatible with the ARC (Audio Return Channel) feature on your ONN Roku 40 TV. Here are a few suggestions to potentially solve the issue:
1. Ensure that both your TV and the Bytecc 4K2K LPCM 7.1 Extractor support the ARC feature. Check the user manual for the specific HDMI port on your TV that supports ARC, as not all HDMI ports may have this feature.
2. Double-check your TV audio settings. Make sure the audio output is set to HDMI ARC, and if there's a setting for audio format, choose LPCM.
3. Try using a high-speed HDMI cable that supports Ethernet, as the ARC feature requires this type of cable.
4. Perform a factory reset on your Extractor and reconnect it to the HDMI ARC port on your TV.
