20 Most Recent
PANDIGITAL 7 Android with 2GB Internal Storage 256MB Memory Black Questions & Answers
Why does the battery flash from red to green while charging?
If it changes from red to green and stays green while being charged, it is just a sign that it is being charged and there is nothing wrong.
If it flashes back and forth between red and green while charging, there might be something wrong with your charger's connection.
I need a n ew DC power jack for my pandigital
Most of the Pandigital tablets use the power adapter APR001 which provides 5V at 2A. This is available from Geeks.com here:
http://www.geeks.com/details.asp?invtid=APR001 . Other vendors may also have the adapter.If you need to replace the jack where the adapter connects, try Radio Shack or
http://www.mcmelectronics.com . You need to measure the existing jack dimensions carefully. (This ensures that the adapter will connect properly.) When you desolder the old jack and solder in the new one, make sure that you keep the polarity the same. (Otherwise the adapter may not work.) I hope this helps. Cindy Wells
My screen is cracked
If you have a warranty you can call a customer service number or go to a website that may be listed on the manual of your electronic or box it came in. Also if you don't have a warranty you can type in the make and model of your electronic and look up screens on line.
Will not charge
Usually the reason a electronic will not charge is because the charger is usually shorted out or damaged. You might need to get a replacement.
My pandigital android tablet will not turn on or off it just keeps trying.
I had that problem too. Your firmware is corrupt. You will need to go to http://www.pandigital.net/pandigitalnovel and click on "Firmware Updates Click Here" Link and follow the instruction. You might need to copy the firmware directly to the SDcard root /sdcard and reboot your tablet by pressing on the power button AND the UP volume button at the same time until you see the reboot sequence screen. Good Luck
