20 Most Recent LG SuperMulti Network Attached Storage N1A1DD1 Network Storage Server Questions & Answers
Tip
How to remove hard drive
There is a single screw under the sticker on the bottom that says the warranty will be voided if you remove it. Remove that sticker and unscrew that black screw.
Then one of the white panels (the one closest to the actual hard drive) will slide towards the front of the enclosure when you push outward on the two black panels enough to clear the white tabs from the big white panel.
on Apr 23, 2015 | LG SuperMulti Network Attached...
You could try holding the widget until you can drag it to the remove section, see instructions here:
https://www.wikihow.com/Remove-Widgets-on-Android
LG Computers &... | Answered on Feb 04, 2020
It typically points to a configuration or network connectivity issue that is preventing your device from reaching the Netflix service. Follow the troubleshooting steps for your device below to resolve the issue.
Blu-ray Player Nintendo Wii U PlayStation 3 PlayStation 4 Roku Set-top Box or Streaming Media Player Smart TV Xbox 360 Xbox One
LG Computers &... | Answered on Jan 15, 2020
simple. just make sure all the cable connected to our lg screen don't loose. or chech the quality of your cabel behind the screen.
LG Computers &... | Answered on Dec 09, 2019
Yes, the LG 52LB9DF is a full high definition television with 1920 x 1080 resolution. LG has the specification sheet on the product page: https://www.lg.com/us/support/product/lg-52LB9DF.AUS . The current link to the specifications is https://www.lg.com/us/tv-audio-video/pdf/h_52lbx_spec_sheet.pdf .
I hope this helps.
LG Computers &... | Answered on Dec 03, 2019
Go to Settings, click on WIFi, click on the three dots on to top right of the screen, select Advanced Wi-Fi, then turn on Auto Connect to WiFi and Wi-Fi Notification
LG Computers &... | Answered on Nov 02, 2019
it's may be error of the hard drive. therefor remove and reconnect ,if not fix pls connect to another pc and test. or replace the hard drive.
LG Computers &... | Answered on Oct 11, 2019
This requires more technical in person diagnosis. some things you can try are to boot in to the bios menu.
  • To do this you will have to watch as it is turning on and on one of the startup screens it will tell you to press one of the function keys (F10, F2,F12, and so on) click the one that says "bios" or "settings".
  • After that you will need to search through all the settings for something called the "IDE self test" run that once, it will take a while.
  • and lastly look for another option called the boot order. you have to make sure that the option that says hard drive is first.
I am sorry i can't be of more assistance but not much can be done without seeing the laptop.
LG Computers &... | Answered on Aug 25, 2019
On the phone you would need to gointo settings > wireless and enable your wireless radio. You should then get a notification that wireless networks are available. Select your's or a public wireless network if you're at a coffee shop, ect. Enter any applicable passwords. For this to work you need to verify your phone has wireless capabilities and that the phone and router support the same 802.11 standard. Current Standards are a,b,g,n and ac
LG Computers &... | Answered on Aug 22, 2019
The address bar may have been hidden in the settings options, usually it is near other settings such as "show Menu bar" and "show bookmarks Tab" etc
LG Computers &... | Answered on Aug 15, 2019
LG SuperMulti Network Attached Storage N1A1DD1 Network Storage Server Logo
2 questions posted
Top LG Computers & Internet Experts
Ekse
Troy Staley
Troy Staley
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • LG Computers & Internet
Most Popular Question
lg intellowash 8016c in storage several
  • Computers & Internet
