20 Most Recent D-Link DP-G321 Print Server Questions & Answers
Call Printer support phone number 1-888-687-4491 USA Toll-free and find instant support.
D-Link DP-G321... | Answered on Feb 21, 2018
Laserjet 1020 is a host-based (WIN) printer. Won't work on DP-G321.
Connect using USB to a PC and share it.
D-Link DP-G321... | Answered on Aug 05, 2014
You should set Preamble to Short (default is Long) in the WiFi configuration page.
D-Link DP-G321... | Answered on Apr 04, 2012
- change the cable
- assure your plug.
D-Link DP-G321... | Answered on May 13, 2011
It sounds like your windows went into a temporary profile, this is nothing to do with your router. This is a windows problem. i've attached a link that gives you step by step to fix for windows 7 machine.
http://www.winhelponline.com/blog/fix-windows-easy-transfer-error-using-temporary-profile-windows-7/
D-Link DP-G321... | Answered on Mar 07, 2011
You need to use the SSID of the wireless router on the print server. Any wireless security applied to the router must also be applied to the print server. Otherwise you have two seperate wireless networks.
D-Link DP-G321... | Answered on Sep 02, 2010
check in page setup plz
D-Link DP-G321... | Answered on Jun 25, 2010
Yes, but it run like 64 bit, because of the other devices.
D-Link DP-G321... | Answered on Dec 16, 2009
I am currently using this print server with the HP Laserjet 1100 on the parallel port and it works flawlessly.
D-Link DP-G321... | Answered on Apr 01, 2009
According to its Datasheet, it will only work with the following Operating Systems:
- Windows 98, ME, 2000, XP
- MacOS EtherTalk
- Unix
- NetWare 5.0 or above (Native NDS)
- lpd
You can go to this link to download its Datasheet.
ftp://files.dlink.com.au/products/DP-G321/Datasheet/DP-G321_datasheet_01.pdf
D-Link DP-G321... | Answered on Mar 08, 2009
Hello Kawena66,
There may be an ip conflict as the error suggest.
what is the ip address on your XP system?
D-Link DP-G321... | Answered on Sep 19, 2008
There should be a pinhole that allows you to do it with a paper clip...
D-Link DP... | Answered on Feb 16, 2014
the manual is free , at dlink dot com
you push the reset button for long time per manual 15sec (iirc)
the release it and now all defaults are set.
per the manual, google dir-655 manual.
easy as pie if you just read the manual.
D-Link Computers... | Answered Yesterday
There's a reset button on the back of the router, it's a small button that you can press using a paper clip. Press it for 15 seconds to reset it.
Reset 1:
Press the reset button for 15 seconds at the back of the router while the router is on.
Reset 2:
Press the reset button for 15 seconds while the router is on after 15 seconds unplug the power cord while holding the reset button then count another 15 seconds and release the reset button. Then plug the power cord back in.
Reset 3:
Press the reset button for 15 seconds while the router is on after 15 seconds unplug the power cord while holding the reset button then count another 15 seconds and plug the power cord back in while the reset button is plugged in and count another 15 seconds release the reset button.
Hope this helps.
D-Link Computers... | Answered on Dec 04, 2019
D-Link DP-G321 Print Server Logo
20 questions posted
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
DP D-Link
  • DP D-Link
Most Popular Question
cannot connect wirelessly direct
  • Computers & Internet
