20 Most Recent Dell Wireless 2350 Router Questions & Answers
How to connect to network?
This WEB site shows how to setup a network.Home Network Guide, routers, print servers etc.http://sites.google.com/site/networkguidedemo/home
4/10/2012 11:56:26 AM • Dell Wireless... • Answered on Apr 10, 2012
Hey ! I've got a DELL
My first thought would be to try different forms of encryption on your router. It's possible that your printer may not support the type of encryption you're trying to use which may be causing it to have trouble connecting. For example, if you're using WPA encryption, try switching to a WEP key instead. You can change all of these settings from your Wireless Router's configuration page.
7/24/2011 6:59:07 PM • Dell Wireless... • Answered on Jul 24, 2011
Canh not get the computer
Did you type 192.168.2.1 on a browser's address bar? If your computer is part of you wireless router's network that should open router's configuration page.
Default user name:admin
Default password:admin
Thank you!
7/11/2011 2:20:09 AM • Dell Wireless... • Answered on Jul 11, 2011
0answers
I forgot the username for
Thanks for contacting Fixya.com
This is bad as if you happen to be on a domain, you can contact your system administrator to change your password for you. If you're not on a domain and there are no other administrator accounts on your computer and you do not have a password reset disk, you'll need to reinstall Windows 7. Also before formatting reboot into safe mode - F8. Change log in screen to administrator, first try leaving the password blank, hit enter. See if this works.
To make sure this doesn't happen in the future, create a password reset disk - http://windows.microsoft.com/en-US [...] reset-disk
Let me know if you need any further information.
5/6/2011 5:28:43 AM • Dell Wireless... • Answered on May 06, 2011
I have my network open
Hi.
First, you need to access your router.
To do this, open a browser, and in the address bar type in: 192.168.1.1
This takes you inside the router's web access program.
From here you can change settings like security.
here as all the instructions for changing it.
  1. Type the following text in the user name and password fields: "admin".
  2. Go to the Basic Settings menu option tab on the top navigation bar and wait for the menu to appear.
  3. Click the Wireless Security menu option in the drop down menu.
  4. Click to select Enable Wireless Security.
  5. Click to select either WEP or WPA in the Network Authentication list.
If WEP is selected
  1. Select hexadecimal or ASCII characters as the Key Format. You can use either as a string of hexadecimal digits (characters 0 through 9 and A through F ) or as ASCII characters (any key on the keyboard).
  2. Select an encryption level from the Key Length list.
  3. Enter four different keys in the Key1, Key2, Key3, and Key4 fields to store on your router. For 40(64)-bit encryption, enter a 5-character (or 10 hexadecimal digits) WEP key. For 104(128)-bit encryption, enter a 13-character (or 26 hexadecimal digits) WEP key.
  4. Select only one key out of the four keys as the Default Key for encryption.
  5. Click the NEXT button, and then click Save and Restart to apply the changes.
  6. Set up WEP encryption on your wireless clients. Refer to the documentation that accompanied your wireless clients, or your wireless clients' on-line help systems, for information on how to set up WEP encryption.
If WPA is selected
  1. Enter your pre-shared key. This key must match the key that is used by each wireless client computer associated to your router.
  2. Choose a key format. This can be hexadecimal digits (0-9 and A-F) or ASCII characters (any key on the keyboard).
  3. WPA Group Rekey Interval specifies how often the key "rotates" or changes.
  4. WPA Encryption allows you to select one of two possible encryption methods-TKIP and AES. Choose one that your wireless clients support.
  6. Set up the WPA on your wireless clients. Refer to the documentation that accompanied your wireless clients, or your wireless clients' on-line help system, for information on how to setup WPA.
I know it looks like a lot of information, but really it's not.
Just follow these steps and you're security eill be set up in no time, and then you can rest your fears about someone else using your network without your permission.
NOTE:
NEVER store the password in your computer, because in the event of an infection, that information could be stolen.
Write whatever your new password is down, and keep it safe somewhere. That way, if someone does want to use your network, they will have to ask you for it, and you will have it for them.
I hope this gets you going the way you want!
2/8/2011 3:17:00 AM • Dell Wireless... • Answered on Feb 08, 2011
The wireless router i have came with a used laptop
Hi. Thanks for your question on how to change you password in router which will show you how to ge in to your routers settings. --------> http://www.fixya.com/support/r4695161-change_wireless_network_password_forgott
Please note since you can connect to your router through wireless you don't need to connect with cable. Just ignore this in tutorial.
Once your in there you need to go to wireless tab and change security settings. You want to change your network to be secured by WPA-PSK which is a very strong. Then you need to provide password that you would like router to have. Once you've done this save changes and refresh your wireless networks. You should see yours being secured now and you should need to provide password to get to it.
I hope this helped you. Thanks you for using FixYa
12/14/2010 3:45:00 PM • Dell Wireless... • Answered on Dec 14, 2010
Would like to add security password for wireless
http://support.dell.com/support/systemsinfo/document.aspx?c=us&l=en&s=dhs&~file=/network/2350/en/intro/wireless.htm#encryption
The link above is the User Guide to the Router. This will tell you how to encrypt the network and reset the router password.
11/4/2010 8:12:17 PM • Dell Wireless... • Answered on Nov 04, 2010
Can't connect to router by wireless and by local
Locate the MAC Address for the Computers You Want to Use for Gaming
1. Click the Start button.
2. Click Run.
3. In the Open box, type the following text:
cmd
4. Click the OK button.
The command prompt screen appears.
5. At the command prompt, type ipconfig /all
6. Write down the MAC (Physical) address of your computer to configure for gaming.
Change Router Settings
1. Open a web browser, and type http://my.router, or http://192.168.2.1. The Enter Network Password login prompt appears.
2. Type the following text in the user name and password fields: "admin".
3. Go to the Advanced Settings menu option tab on the top navigation bar and wait for the menu to appear.
4. Click the DHCP Server Settings menu option in the drop down menu.
5. Click the Add button in the IP Address Reservation section.
a. Enter the MAC address of the computer you wish to use for gaming in MAC Address field.
b. Enter an IP address for the computer.
6. Click the Submit button.
7. Go to the Advanced Settings menu option tab on the top navigation bar and wait for the menu to appear.
8. Click the Port Forwarding Settings menu option in the drop down menu.
a. To set a single computer for gaming, click to select Enable DMZ Host.
b. Enter the IP address of the computer in the DMZ IP Address field.
c. Click the Submit button.
NOTE:
Only a single computer can be set for DMZ service. To set multiple computers for gaming, please refer to the Custom Port Forwarding Settings under Port Forwarding Settings.
9. Reboot the client computer. The client computer will use the newly assigned IP and will not have any TCP/IP ports blocked by the firewall feature of the router.
10/29/2010 3:50:57 PM • Dell Wireless... • Answered on Oct 29, 2010
I am using a Dell 2350 router but even though the
Go to http://support.dell.com/support/edocs/network/2350/en/index.htm
10/21/2010 9:15:17 PM • Dell Wireless... • Answered on Oct 21, 2010
One day I was playing
Do a restore by pressing the RESET button at the back of the router. Uninstall and reinstall the firmware.
Another option is use the Google Translator. Just copy and paste the phrases there and hit translate so that you can get it back to English.
All the best! If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
10/13/2010 6:47:44 PM • Dell Wireless... • Answered on Oct 13, 2010
Trying to connect and it is asking for a network
  1. Log into the web configuration of your router at http://my.router, or the default address http://192.168.2.1. The Enter Network Password login prompt appears.
  3. Go to the Basic Settings menu option tab on the top navigation bar and wait for the menu to appear.
  4. Click the Wireless Security menu option in the drop down menu.
Under this, you might be protected by either WEP or WPA security. Now you will be able to see your password.
For any further clarifications, please revert!
Thanks for asking,
Regards,
Arvind S Iyer
9/28/2010 2:24:50 AM • Dell Wireless... • Answered on Sep 28, 2010
My Dell 2350 router was
Hey!
Looks like someone pressed the reset button on your router which caused it to go back to it's factory settings that's why you lost the password.
Click here for the user manual regarding network security setup for your Dell Wireless Router.
Hope this helps! :D
9/8/2010 11:39:42 PM • Dell Wireless... • Answered on Sep 08, 2010
Default login and password
reset the router buy holding the rest button down for 10 seconds once all the lights start to blink leave it for 20 seconds or more so the lights get stable and then use the default user id admin and password admin
Don t forget to say thanks
admin
8/18/2010 5:01:10 PM • Dell Wireless... • Answered on Aug 18, 2010
How do I change the
google that exact question, and check some of the xbox forums, also check your router manual
7/31/2010 9:46:49 PM • Dell Wireless... • Answered on Jul 31, 2010
Am trying to reset my router completely how do i
There should be a small reset button on the bottom or back of the router. You'll need a paper clip. See if you can find a manual on your router because you may need to hold it down for some length of time (as long as a minute) or unplug the router and plug it back in while your holding the button in, etc. You can try different methods if you can't find a manual.
7/6/2010 4:06:48 AM • Dell Wireless... • Answered on Jul 06, 2010
Is the antenna removeable?
Yes. Typically they can be unscrewed from the back, but each model has its own intricacies, so you may want to look for a specification/data sheet for it.
5/17/2010 11:13:12 PM • Dell Wireless... • Answered on May 17, 2010
Dell 2350 router configuration problem
Have you tried to use auto settings at ip adress, maigate and dns configuration at the laptop? Is it possible to browse the internet when the laptop is cable connected at the router?
Waiting clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
5/15/2010 10:00:50 PM • Dell Wireless... • Answered on May 15, 2010
No internet connection via router
1. check your firewall settings.
2. Go to the router and check the status by entering into a browser page 192.168.0.1 or 192.168..1.1 this will bring you to the routers setup page and active icons. choose the status.
3. You can unplug the router reboot the PC for one minute and try connectivity again.
4. check the ISP to check you connection even though you say that it is OK.
4/23/2010 4:22:13 AM • Dell Wireless... • Answered on Apr 23, 2010
Dell Wireless 2350 Router Logo
Popular Tags
103 questions posted
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
View Most Popular
  • Dell Computers & Internet
Most Popular Question
trying connect asking network
  • Computers & Internet
