20 Most Recent Dell A425 Computer Speakers Questions & Answers
MY DELL MODEL A425 SUB subwoofer main IC HAS BEEN DAMAGE KINDLY SEND THE IC NUMBER
Dell A425... | Answered on Aug 23, 2015
i have the same speakers.
but isntead of one side going,
both sides are dead.
and the light on the control side doesnt even turn on
it is plugged in
but i do not know what is wrong
solutions please?
darkhunter234@hotmail.com
Dell A425... | Answered on Mar 23, 2014
If it is happening, Take a magnetic screw driver and move around inside the sub woofer any how , The magnetic screw driver will collect your spare screw .If it will be not done please remove the sub woofer remove all the screw and then you will do it.
if it will help you dont for gate to vote me.
Dell A425... | Answered on Aug 08, 2012
pull off front plastic grill to access four screws on the speaker itself. Unscrew 10 screws on back to pull out the power board. The transformer is screwed to the bottom (4 screws).
http://support.dell.com/support/topics/global.aspx/support/kcs/document?c=us&l=en&s=gen&docid=DSN_E876EF53BCA3F058E030030ABD6260B2&isLegacy=true
Dell A425... | Answered on Jan 20, 2012
It's possible that the power adapter that gives power to the speakers, is faulty. It's also possible that some electronics inside the speakers is faulty, this could also be the power button on the speakers.
Take your speakers and the adapter to an electronics store in the market and ask the shopkeeper to try an exact adapter and check if it powers up the speakers.
If the speakers power up, then buy the adapter. If they don't, then the problem is with the speakers and you may have to contact an electronics repair shop. Or, just get new logitech speakers. They are cheap nowadays.
Hope that helps,
Regards,
Raspal
Dell A425... | Answered on Dec 09, 2011
Check the equalizer in Itunes to make sure you don't have it set to the highest values. This could be the reason why your speakers are playing the music with static.
Here is video that will help you access the equalizer: http://www.videojug.com/film/how-to-use-your-itunes-equalizer-2
Dell A425... | Answered on Aug 30, 2009
Dell 4700 Check the video card fan. Had one that was full of dust..Cleaned it and moved the sound card away from the video card.. this fixed my problem.
JZ
Dell A425... | Answered on Feb 15, 2009
The DJ 30 is no longer supported by Dell.
Dell Audio... | Answered on Feb 10, 2019
If there is no separate power supply the usb plug must be used in order to provide power for the speakers, but whether the analogue cable must be plugged in or not will depend on the internal construction and specification of the speakers.
I suggest you initially use the usb and if there is no sound and no on-screen instructions, plug in the analogue line.
If there is a separate power supply the speakers are probably and either/or design.
Dell Audio... | Answered on Dec 04, 2018
19 questions posted
Top Dell Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Ekse
Marvin
Marvin
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Dell Audio Players & Recorders
Most Popular Question
took out bottom
  • Audio Players & Recorders
