20 Most Recent
ASUS K52JK PC Notebook Questions & Answers
My laptop crashed when i am playing ONLY League of Legends sometimes
Sometimes games will freeze up due to a video card driver needing updated or replaced. Another reason could be that it has a corrupted file and needs re-installed. You can always try running a disk defrag also to see if that helps. Your graphics card might not have what it takes to run it, you could try lowering the settings.
The requirements for games are not 100 percent accurate as it depends on a lot more than just system hardware. Different drivers, versions of codex, as well as different versions of direct x all can affect it. Even just how well the game was coded and or optimized can affect it a lot. If I remember from what I did play of it, they didn't have that well of an optimized game.
One last thing to try is in your league folder there should be a direct x setup application. Try running that to see if that works.
links:
How to Defragment Disk on Windows Computer
Notebooks Ultrabooks K52JK
Indie game developer, Neon Chainsaw LLC.
PC Tech I’m happy to assist further over the phone at
https://www.6ya.com/expert/wesley_57e7f19c14a313b1
Bad systems time
There are 2 clocks on a computer the OS (obvious) and the BIOS. This is the one keeps time even when powered off. Verify and correct time there.
How to drag with mouse
Simply left click and hold on the item you wish to drag, then move the mouse to where you want it to be - then release the left mouse button.
Remove internal memory
Click start, all programs, accessories, click command prompt, enter mdsched.exe, this will check your memory.
Fn key unlock
you can try try clean and reseat the kb-cable. If the same problem persists, buy anotther kb.
