20 Most Recent
Marinco Guest 2620 Waterproof Charger Questions & Answers
I have a dual marine battery charger on my boat that is wired thru a 1-2 or both switch both batteries are 12 v batteries and i was wanting to know if i could add another two 12v batteries to the sy
It sounds to me like you have an Ad-A-Battery system or something similar. Your dual battery charger has two sets of output leads. Those leads should be connected DIRECTLY as one set of leads to battery #1 and one set of leads to battery #2. Your 1-2-both switch should be OFF when you are charging. You will, I suspect, be supplying current to your motor and other boat circuits by having the switch on and running your charger through that switch. Adding two more batteries could be accomplished by buying a four battery charger (four sets of output leads) or buying a second dual battery charger. When you only want one AC plug-in you connect both charger AC inputs to a small junction box that is fed current by the AC plug-in. That will be nice and simple and safe. Of course, you need to check wire size to make sure you have proper size for the length of your wire runs.
3 marine batteries on a dual charger
You don't. It is called a "dual" battery charger for a reason, it charges two batteries. Guest makes very nice three battery chargers. Buy one of those and install it as per the instructions. You'll be much happier as well as safer.
I just bought a new boat and need to buy a boat
Never buy a trailer with the same capacity as the weight of your boat! This can be very dangerous! Instead, make sure the trailer's capacity is at least twice that of the weight of the boat, all your gear, and the boat's motor.
12/5/2023 6:58:35 AM •
Boating
Answered
on Dec 05, 2023
What is the size of a small yacht?
Small yachts, also known as Silboats or Cabin
Cruisers are 20-40 feet. There are of course larger Yachts that can get to over
100 feet, also known as Mega Yachts.
11/15/2023 8:08:55 AM •
Boating
Answered
on Nov 15, 2023
What is the most expensive yacht in the world?
Off-course There are so many companies who are offering expensive yacht charter for rent in and around Europe. I suggest you to enter Kavas is the only yacht chartering company in Greece with over 25 years of experience in our industry. Kavas is offering all range from reasonable to luxury yacht services in Athens, Kos Island and Lefkas Island. For more details visit
Bareboat or Crewed Yacht Charters in Greece
10/13/2023 4:52:02 PM •
Boating
Answered
on Oct 13, 2023
