20 Most Recent
Passport 8500 Radar Detector Questions & Answers
Where do I send the unit in for service (factory)
I'm sorry, but I would need more information about the specific unit you are referring to in order to provide an accurate answer.
Generally speaking, the manufacturer's website or customer support line should have information on where to send a unit for service. You can also try searching for the nearest authorized service center or dealer using the manufacturer's website or a search engine.
If you can provide me with more details about the unit, including the brand and model number, I may be able to provide more specific guidance.
Service Required on 8500
Hold all THREE buttons, one is located on the front right of the detector, while turning the detector on.
Escort 8500 radar detector
Service Required means that your 8500 has repeatedly failed while attempting to calibrate its radar antenna. This can be fixed by Escort for free if your RD still is in warranty. There is a service fee if your RD is out of warranty, but at least Escort will fully test everything in addition to repairing your 8500, and they will upgrade your 8500's firmware to whatever their latest and greatest firmware is which may help to improve sensitivity, reduce false alerts, or to detect newer laser gun models.
Error code CA13ERR
why don't u try online websites..
some websites deal in it real time.. along with solutions to problems how to repair fix service nd all
let me know if u need help I know plenty
Got a ticket, passport never made a sound
You may have received a laser hit or a qucik shot on the radar. We don't normally keep the radar on constant - a click of the button sometimes real fast will grab your speed, lock on the display and then the signal will cease to omit.
You may also want to check to see if you are set on city of highway.
It says need to calibrate
Follow the direction of the radar detector. Usually you push the button sequence for calibrate and you drive the car in two circles so it can calibrate the compass.
Laser warning going off all the time
Hi All,
I fixed my Radar, No Manufacturer help, no cost to me at
all. I got advice from a forum member on a satellite forum I belong to.
So what I did was I took apart the radar. Watch carefully how it comes
apart so you can reassemble again after. Get a Dry Q-tip (ear swab)
leave it dry so you do not end up leaving and residue on the diodes
etc. Start by cleaning the horn, wipe the electronic board all over
gently with the Qtip , blow ou the diffusion screen (leave the spit in
your mouth). After all that I did not see a spec of dirt on the Q tip I
used..there was
no sign of dirt, residue but whatever I did do
fixed the problem. I have been using it for three months and not one
false alarm from the laser mode.
Good luck all......
I need a power cord for my 8500 passport
Hi, I would just write a polite email to the manufacturer and say you have miss placed it while changing vehicles and stress how much you miss the use of there invaluable product.
(this can work to get it free or a bit cheaper)
