20 Most Recent Samsung SMH1713W Microwave Oven Questions & Answers
My Samsung microwave won't turn on
There are many other components that can fail. A Samsung is worth getting professionally repaired. https://www.fixya.com/support/r29874712-repairing_microwave_ovens ..
9/1/2023 12:08:01 AM • Samsung... • Answered on Sep 01, 2023
Samsung smh1816s fan comes on when door open and now whole unit is dead.
where did you buy it?
8/15/2023 1:53:04 PM • Samsung... • Answered on Aug 15, 2023
Samsung microwave oven model #ME21K7010DS/AA
Judging from reviews of this model on Samsung's website, this is a common problem. Does it happen during or after using the cooktop or range below the microwave oven? In particular, is it most common when using the burner directly under the microwave oven control panel? If the issues are correlated to heat or humidity from cooking on the range top, I would suspect problems with moisture in the keypad circuitry. I would consider cleaning the controller board key panel connector area with 90%+ isopropyl alcohol (this is an internal service on a circuit board that is most likely susceptible to damage by static electricity, so it should be done by someone who knows how to service electronics). This should remove contaminants that could cause current leakage between keypad connections (spurious keypad entries) in humid conditions. Let the board dry thoroughly before reconnecting. It's also possible that moisture is getting into the keypad assembly. This would be a design/manufacturing flaw. I would guess the oven is out of warranty, so the fix would be to put the keypad in a dessicator for a day or so, then seal the edges with RTV Blue or a similar caulk that does not release acetic acid (vinegar) during the curing process. (Acetic acid even in vapor form may corrode the silver contact material in the keypad.) Do not seal the connector, just the edges of the flex ribbon layers where moisture can get into the key membranes. In the meantime, always use the microwave oven fan when cooking on the range. This will help to keep the controller cool and dry. (Samsung's troubleshooting guide says the fan will turn on automatically if the microwave oven gets too warm from cooking underneath it.)
3/16/2023 8:51:25 PM • Samsung... • Answered on Mar 16, 2023
Hi i have Samsung Model GE0103MB microwave and i took it for repairs and the bottom switch is not engaging
It sounds like you are having difficulty with the bottom switch on your Samsung Model GE0103MB microwave not engaging with the door release button. This can prevent the microwave from functioning properly and could be caused by a few different issues:
  1. Make sure that the switch is properly connected to the door release button. The switch may have been installed incorrectly during the repair process, which could prevent it from engaging properly.
  2. Check the door release button to ensure that it is not damaged or malfunctioning. The door release button could be preventing the switch from engaging properly.
  3. Check the wiring connections to the switch and door release button to ensure that they are secure and not damaged.
  4. If you are having difficulty assembling the microwave, I suggest you to try and get the service manual or a diagram of the assembly process for your specific model GE0103MB. You can try searching for it online or contacting Samsung customer service, as they may be able to provide you with the information you need.
  5. If the problem persists, you may want to contact a qualified technician to service the microwave and inspect the door switch and door release button.
It's important to note that working on a microwave oven can be dangerous and should only be attempted by someone who is familiar with the inner workings of the device, and have the proper tools and equipment.
1/14/2023 10:45:45 PM • Samsung... • Answered on Jan 14, 2023
Samsung MW82Y microwave acting strange.
Now you know why they were selling it, it doesn't work and needs dealer service! https://www.fixya.com/support/r29874712-repairing_microwave_ovens ..
12/23/2022 5:16:55 PM • Samsung... • Answered on Dec 23, 2022
I have a Samsung ME18H704SFS- overheating help.
It will be fine. They aren't made for sustained cooking on high power. Popcorn is dry but oiled, so it gets very hot and burns. You can use the glass carousel plate or replace it. Depending how big the crack is, any water in the crack will finish it off. A new glass tray is $57. A new Microwave the same is $319. Samsung are one of the better makes. https://www.google.com/search?q=samsung+me18h704sfs+replacement+glass+plate ..
11/27/2022 3:04:28 AM • Samsung... • Answered on Nov 27, 2022
2answers
Got nc error code on my roadmate can anyone help
Nc means theres most likely an inverter fault inside the oven. This can be repaired cheap. Contact me for info.
7/10/2022 1:23:07 PM • Samsung... • Answered on Jul 10, 2022
Samsung SMH2117 microwave oven.
7/7/2022 3:02:28 PM • Samsung... • Answered on Jul 07, 2022
Samsung microwave door wont close
The small plastic plate on the microwaves door with the spring it it needs to be replaced.
6/29/2022 1:38:18 AM • Samsung... • Answered on Jun 29, 2022
2answers
How do you fix the fault code E-32 on a samsung microwave
E-32 error means you have a wiring or circuit board short. Easier or cheaper to replace without a lot of aggrevation.
11/9/2021 6:28:09 PM • Samsung... • Answered on Nov 09, 2021
Display on Samsung Microwave Model SMH9207ST is very dim. Almost totally dark.
At 12 years old, time for a new control panel.
11/8/2021 6:46:09 PM • Samsung... • Answered on Nov 08, 2021
Samsung Microwave SMH1816S
Switch it off from the wall for a few seconds , then witch it back on and set the clock , this should reset it , if not contact a service man .
10/29/2021 7:33:01 AM • Samsung... • Answered on Oct 29, 2021
Samsung toast and bake microwave keyboard membrane
TRY A DEALER
10/3/2021 8:45:28 PM • Samsung... • Answered on Oct 03, 2021
I need Samsung classic collection MW3500T manual please
Contact Samsung directly to request the manual or do an online search.
9/6/2021 6:29:40 AM • Samsung... • Answered on Sep 06, 2021
I've got Samsung smartsensor micro wave oven.Stuck by "door" on the screen tried everything to work no sucess
1. Damaged or defective door interlock 2. Defective control board
6/2/2021 12:02:44 PM • Samsung... • Answered on Jun 02, 2021
Display not working on Samsung SMH9207 over the range microwave. How can I fix it
Either the display or the control board could be at fault.
3/23/2021 2:02:06 AM • Samsung... • Answered on Mar 23, 2021
What does error code c_do mean?
It is prompting you to close the door, but if the door is closed already, the code may be an indication that the door interlock or associated wiring is at fault.
3/14/2021 3:14:14 AM • Samsung... • Answered on Mar 14, 2021
Samsung SMH1713W Microwave Oven Logo
5 questions posted
Top Samsung Microwave Ovens Experts
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Microwave Ovens
Most Popular Question
samsung smh1713w overhead microwave
  • Microwave Ovens
