20 Most Recent AT&T El52300 Cordless Phone Questions & Answers
Had a att el52300 base that went bad so bought another one it seems to be working ok. all head sets have out of Range or no Power at base.Tried to clear with answer given but nothing worked Need help
Hi, Try the following: 1/ Make sure the power cord is securely plugged in at the base and that it's powered on ie: light is on and working etc.. 2/ Reset the telephone base. Unplug the electrical power. Wait for approximately 15 seconds, then plug it back in. Allow up to one minute for the cordless handset and telephone base to reset. 3/ Place the cordless handset in the telephone base for one minute to allow the cordless handset and base to synchronize. Manual available here: at&t el52300 manual -Charles
7/2/2016 12:41:34 PM • AT&T El52300... • Answered on Jul 02, 2016
At&T EL52300--one phone reads 'out of range-move closer to base.' I did--it doesn't help. Battery OK---What do I do?
It appears that the one handset has become orphaned and must be de-registered and then re-registered. 1. To de-register the orphaned handset from the old base: When the orphaned handset says "Connecting..." or "Out of..." enter *331734 [menu] and it will soon beep and display "Not registered" 2. To register the new handset to your base: press the "Handset Locator" button on the base and hold it until the "in use" light comes on ( ~ 4 seconds ), then release the button and set the new handset into the base phone cradle. After ~ 30 seconds it will beep and display "Handset #" (next in sequence). 3: Note: the base handles a maximum of 12 handsets. If your system was fully populated ( ie, a handset is already # 12 ) you will have to clear all the handsets from the base and re-register them all in sequence. ( it is the only way to 'rescue' the places occupied by the lost handsets ). To clear the base of all registrations: 1. Press and hold the the "Handset Locator" button until the "in use" light lights and then starts to blink ( ~ 10 seconds ), release the button -- then press it again briefly while the "in use" light is still blinking. 2. The base will beep and all handsets that were registered will display "Not Registered" 3. Follow the instructions above for each handset in turn to re-register them: press "Handset Locator" ~ 4sec ( in-use light on ), set handset into the base cradle, etc. The manual is available from: www.manualslib.com but does not fully describe these procedures. Good luck !
5/12/2016 6:04:20 AM • AT&T El52300... • Answered on May 12, 2016
How to register additional handset for AT&T EL52300
Easy to do, even if the new handset is used & orphaned from its original base...simply de-register it from the old base and re-register it to your base. 1. To de-register the orphaned handset from the old base: When the orphaned handset says "Connecting..." or "Out of..." enter *331734 [menu] and it will soon beep and display "Not registered" 2. To register the new handset to your base: press the "Handset Locator" button on the base and hold it until the "in use" light comes on ( ~ 4 seconds ), then release the button and set the new handset into the base phone cradle. After ~ 30 seconds it will beep and display "Handset #" (next in sequence). 3: Note: the base handles a maximum of 12 handsets. If your system was fully populated ( ie, a handset is already # 12 ) you will have to clear all the handsets from the base and re-register them all in sequence. ( it is the only way to 'rescue' the places occupied by the lost handsets ). To clear the base of all registrations: 1. Press and hold the the "Handset Locator" button until the "in use" light lights and then starts to blink ( ~ 10 seconds ), release the button -- then press it again briefly while the "in use" light is still blinking. 2. The base will beep and all handsets that were registered will display "Not Registered" 3. Follow the instructions above for each handset in turn to re-register them: press "Handset Locator" ~ 4sec ( in-use light on ), set handset into the base cradle, etc. The manual is available from: www.manualslib.com but does not fully describe these procedures. Good luck !
5/12/2016 5:57:40 AM • AT&T El52300... • Answered on May 12, 2016
0answers
Add a handset
Be the first to answer 7/19/2014 7:30:00 AM • AT&T El52300... • Posted on Jul 19, 2014Be the first to answer
0answers
0answers
2answers
How to clear ALL memory from 4-set of (now disconnected) AT&T Model CL82401??
There is a way to delete all calls in the Caller ID log. With the phone system in standby mode, press Menu/Select (key to the upper right of the arrow keys). Scroll (up/down arrows) to Caller ID log. Press Menu/Select again. Scroll to Del all calls and press Menu/Select. You should see a Delete all calls? Press Menu/Select to confirm. There is no corresponding way to delete all old speed dial or directory listings. The manual for the CL82401 is available here: https://att.vtp-media.com/media/p/document2/products/%7B60627918-4BDE-494D-8537-E265D7649708%7D/CL82201_CIB_2_611.pdf . See page 42 for the information on deleting the caller ID log. See pages 36 and 38 for the directory and speed dial items. I hope this helps. Cindy Wells
12/15/2023 3:52:36 PM • AT&T Lands... • Answered on Dec 15, 2023
2answers
AT&T 1830 phone/answering machine. How do I get a manual please?
Question edited for clarity.
AT&T 1830 User Manual - ManualMachine.com
ManualMachine.com https://manualmachine.com > att > 6453-user-manual ANSWERING SYSTEM TELEPHONE 1830. •Installation. •Telephone Operation. •Memory Dialing. •Answering System Operation. •Remote Operation ...
AT&T Product Manuals ' Product Support Center
AT&T https://telephones.att.com > product-support > manuals Find official user manuals and quick start guides for cordless and corded telephones from AT&T.
AT&T Answering Machine 1830 need manual for at&t 1830
Manuals Online http://phone.manualsonline.com > support > att > need... Aug 9, 2012 - Phone manuals and free pdf instructions. Find the user manual you need for your phone and more at ManualsOnline.
12/13/2023 11:07:52 PM • AT&T Lands... • Answered on Dec 13, 2023
How to register AT&T Synj SB67108 to new base unit SB67138?
Register SynJ SB67108 Handset How to register AT&T Synj SB67108 to new base unit SB67138? To register an AT&T SynJ SB67108 handset to a new SB67138 base unit, you will need to follow these steps:
  1. Make sure the new base unit is plugged in and turned on.
  2. Press and hold the "Menu" button on the handset until the display shows "Menu."
  3. Use the navigation buttons to select "Registration" and press "Select."
  4. Select "Base" and press "Select."
  5. The handset will begin searching for the new base unit.
  6. Once the base unit is found, it will be displayed on the handset's screen.
  7. Select the new base unit and press "Select" to complete the registration process.
  8. The handset should now be registered with the new base unit.
Note: if you have multiple handset you need to register, repeat step 2-7 with each handset.
1/22/2023 6:32:18 AM • AT&T Lands... • Answered on Jan 22, 2023
How do I deregister my AT&T CL82313 handset please?
Question edited got clarity. Video should help, similar model. https://www.google.com/search?q=deregister+my+at%26t+cl82313+handset ..
6/28/2022 4:54:29 PM • AT&T Lands... • Answered on Jun 28, 2022
Where can I get a replacement power cord for a handset dock for an AT&T phone model : TL96217
Try AT&T direct https://telephones.att.com/shop The second link might work, but it is a $28 gamble. The first link says specifically that it isn't for the handsets, but doesn't show the end connector! https://www.google.com/search?q=AT%26T+TL96217%2C+replacement+power+cord+for+a+handset+dock ..
1/14/2022 11:55:24 PM • AT&T Lands... • Answered on Jan 14, 2022
Standby mode At&t CL8`301
Do you mean the AT&T CL81301 Cordless telephone? This model doesn't have an answering system. You'd need to adjust the number of rings for your voicemail system through the telephone company's system. See the manual here: https://att.vtp-media.com/media/p/document2/products/%7B40A22BFC-681D-46DC-B836-7CB7C7A691FE%7D/CL81101_CIB_5_610.pdf . If you mean the AT&T CL82301 or the CL83301, first make sure that the system is set to Answer On. Do this with the base Answer On/Off button or through the Menu system (see below for accessing the Answering System menu). You'll need the Answer On/Off line in the handset menu. With the phone system idle (no calls in or out, no one using another handset), press Menu/Select. Use the Up(DIR)/Down(CID) arrows to navigate to Answering Sys. Press Menu/Select. Navigate to Ans Sys Setup and press Menu/Select. Navigate to # of Rings and press Menu/Select. Use the up/down arrows to choose the number of rings and press Menu/Select to Save. Press Off/Cancel to exit the menu system. The manual for this cordless telephone system is available at ManualsLib, https://www.manualslib.com/products/AtAndt-Cl82301-165464.html . See page 47 of the manual, https://www.manualslib.com/manual/643600/AtAndt-Cl82101.html?page=53#manual . Note: if you choose Toll Saver, the answering system will pick up after two rings if you have new messages. It will pick up after 4 rings if there are no new messages. I hope this helps. If you have a different AT&T CL8 * 301, please add a comment with the correct second digit in the model number. Cindy Wells
8/22/2021 9:58:57 PM • AT&T Lands... • Answered on Aug 22, 2021
I need phone manual for AT&T 847. How to assign extension to this model?
http://www.radiomanual.info/schemi/YAESU_HF/FT-847_user.pdf
5/6/2020 7:42:43 PM • AT&T Lands... • Answered on May 06, 2020
I need to purchase a replacement manual for the AT&T TTY 8840 Telephone
actually you can get the manual for free at manuals lib.com
1/27/2020 6:47:56 PM • AT&T Lands... • Answered on Jan 27, 2020
AT&T El52300 Cordless Phone Logo
15 questions posted
Top AT&T Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
AT&T Lands Phones
  • AT&T Lands Phones
Most Popular Question
att el52300 base went bad bought another
  • Lands Phones
