20 Most Recent 2002 Renault Clio Questions & Answers
Renault fault codes
hi there i have a renault clio 57 plate 1.6 auto. it keeps going into safe mode on the gearbox intermitantly. i have read auto trans fault codes which are df241 df240 df242 df243 and df231 which relate too abs sensors.have you any ideas thanks
9/14/2022 10:52:24 AM • 2002 Renault... • Answered on Sep 14, 2022
How to remove the back seats of a 5 door renault clio 2002 model
videos in the link https://www.google.com/search?q=remove+the+back+seats+5+door+renault+clio+2002 ..
5/18/2021 3:34:32 PM • 2002 Renault... • Answered on May 18, 2021
2answers
My clio has shown fault codes df 135 and df 235 what do they mean
I've not had this indication myself, but a quick search found a similar part question about CLIOSPORTS car. In Apr 09 the following advice was given: DF135 Brake pedal sensor circuit, signal incoherence - Memory DF235: Cruise ctrl speed limiter, fault of the two brake pedal contacts Advice: brake pedal switch (have a look in the guides, it just needs adjusting) also the cause of DF235. So faults appear to be connected even if you do not have cruise control. I would have thought if your brake lights function that there should not be a problem. Good luck
1/30/2020 7:00:28 PM • 2002 Renault... • Answered on Jan 30, 2020
Location of Renault Clio crankshaft sensor
I recently tried the DIY service and repair manuals from a website and it actually helped me repair transmission problem in my jcb 3cx site-master. it wont move forward or reverse, engine is good both solenoids for forward and reverse work. I don't have much technical knowledge but I just followed it step-wise, and works perfect! got it from www.reliable-store.com All the best
3/22/2018 3:20:51 PM • 2002 Renault... • Answered on Mar 22, 2018
Where can I find the crank sensor of the Renault Clio 1.4 16v 2002
3/22/2018 3:20:43 PM • 2002 Renault... • Answered on Mar 22, 2018
2answers
Have a renault clio 2002 1.2 The passenger well is very wet and have checked but cant see any issues with seals. today the engine starts to overheat and the water in the resevoir needs about 3 pints
Friend, You've a bad leak in the heater core or a loose connection under the dash. That's where the water is coming from when the carpet is wet on either side. Look up under the dash with the engine running and warm, you'll find the leak. Push the accelerator down a little to make the pressure a little more if you don't see it at first.
3/3/2018 4:55:31 PM • 2002 Renault... • Answered on Mar 03, 2018
Micra immobiliser not turning off
try using a scan tool to reset the ECM having a battery disconnect for any length of time can corrupt the CPU program in the ECM
11/24/2017 12:30:21 AM • 2002 Renault... • Answered on Nov 24, 2017
2answers
Front air bag circuit 1. driver open circuit
This is one of those things you do not want to mess with, you can easily cause the air bag to deploy if you do not know what you are doing. The circuits are static sensitive. I would suggest taking it to the dealer or a good mechanic.
10/1/2017 8:33:27 PM • 2002 Renault... • Answered on Oct 01, 2017
Car wont turn over battery is ok
Check the ignition wire under dash first to see if it gets power. If not then wiggle key while in ignition. Sometimes they go bad. Also check fuses.
10/13/2016 1:19:59 PM • 2002 Renault... • Answered on Oct 13, 2016
How can I get the engine to start
First check the connection unhook both and reattach. Then if that doesn't work check fuse to starter. If still no power. Check the ignition switch to see if it has power or needs replacing
10/13/2016 1:15:16 PM • 2002 Renault... • Answered on Oct 13, 2016
I have a Reanult Clio 2002 , the car turn on but dosent start it keeps on cranking until it cuts off as if there is short of sparking fire can anyone help
run the fault codes to determine the area of fault could be cam/crank position sensors, immobilizer, ignition control module or broken timing belt/chain
9/25/2016 10:35:47 PM • 2002 Renault... • Answered on Sep 25, 2016
Hi I have a 02 Clio expression that runs fine but
try crank position sensor. but would recommend having the car on a fault diagnostic machine to establish a fault code, hope this helps
9/25/2016 10:08:50 PM • 2002 Renault... • Answered on Sep 25, 2016
2answers
Does anyone know the radio security code for my Renault clio?
For Renault radio codes use the service on this link: Car radio codes in Uxbridge London Gumtree
7/30/2016 10:29:02 PM • 2002 Renault... • Answered on Jul 30, 2016
Intermittent fault indicators wipers windows stop working then come on again and then stop
is the linkage good between both wiper arms is the motor good or getting ready to go? check switch and connection to same also fuse
5/5/2016 11:25:41 AM • 2002 Renault... • Answered on May 05, 2016
Speedometer not working
you need to give more information for anyone to know... but I will take a crack anyway. In my expierance, I would guess that the cable to it broke, but it could be that it just got disconnected somehow. if it is digital, then it is a different deal all togather. post your trouble shooting results and I will try to help. good luck. Tim
10/21/2015 8:27:53 AM • 2002 Renault... • Answered on Oct 21, 2015
How long to take out gear box and repair
Kind of depends on what is wrong with it; who is doing the work; what tools are available; are they hurrying and doing poor quality work or careful and slow.
10/2/2015 9:38:16 PM • 2002 Renault... • Answered on Oct 02, 2015
2002 Renault Clio Logo
276 questions posted
Popular Products
Top Renault Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
john h
Are you a Renault Expert? Answer questions, earn points and help others
View Most Popular
Clio Renault
  • Clio Renault
Most Popular Question
reanult clio 2002 car turn but dosent
  • Cars & Trucks
