20 Most Recent
Huawei Impulse 4G Questions & Answers
My Impulse no longer takes my google password
Corrupted software
It
isn't often that Apple gives specific directions about how to fix your
problem! Restoring the iPhone 4S will erase everything on it, so make
sure everything on the iPhone 4S is stored elsewhere prior to restoring.
To restore, connect your iPhone 4S to a computer with iTunes installed.
Click "Restore" on the iPhone 4S summary page (click on your iPhone
icon on the left menu to find this page). Follow the directions to
restore. If your iPhone 4S displays the text "Please wait. Very Low
Battery," leave it plugged in. This charges the iPhone 4S enough to be
able to restore. If the iPhone 4S hangs on this screen for long periods
of time, you may need a new battery. Force restore mode
If
your iPhone 4S is hanging with an Apple logo, or exhibiting some other
software problem that prevents iTunes from recognizing it, you can force
it into recovery/restore mode and then use iTunes to restore the software. If
the device is powered off, plug one end of your USB cable into the
iPhone 4S and leave the other end disconnected. Press down on the Home
button, and keep holding it down while you plug the USB cable into your
computer. After 5-10 seconds, you should see a "Please Connect to
iTunes" image on the iPhone 4S, and iTunes should prompt you to restore
the software; follow the prompts and the instructions given above. If
the device is powered on, hold down both the power and home buttons
until the device reboots and displays the "Connect to iTunes" image
(generally, 5-15 seconds).God bless you
How do i unlock if it has been reported stolen
If your
mobile phone is lost or stolen you can inform your cell phone provider with your IMEI number. Your cell phone provider can then put the serial number on a shared database. This list stops this particular phone from registering on any network and will be useless for anyone even if the mobile phone's
SIM card is changed.
I want to reset my android phone butbi dont know how
Hello My Dear Friend:::defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will Solved
How do i reset my phone
go to setting on your phone and hit master reset and it will erase everything in your phone
How do i unlock my phone after to many attempts
Dear:ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will SolvedIf For puk & pin cod problem So PleaseVery Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office opratorEnter The Puk code and YesEnter The pin code and YesSo Puk code Open and Problem will Quickly Solved
It wont charge
My Dear Brother:First Option:mostly nokia chargers doesn't make problems...just try the following..connect ur mobile with a system (usb cable)...found out whether it is charging or not...if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...if it charged with usb cable buy a new chargerPlease change Phone Bettery and check the chargingIF Charging Problem not Solved SoSecond Option:Your Phone charging IC Fault So Please change charging ICAnd charging Problem will Solved Quickly
Network
Which phone carrier are you using?
AT&T Impulse 4g says phone is charging when it is not plugged in. Will not charge when plugged in!
