20 Most Recent LG Optimus Slider Questions & Answers
Need to unlock my locked LGL55C
When you can't recall your LG Optimus Slider unlock Pattern, PIN or Password: 1. Turn the power off. 2. Press and hold the following keys for over 10 seconds: Volume Down Key + HOME + POWER. 3. You will enter the Android system recovery menu 4. Press Volume down Key to scroll to wipe data/factory reset and press MENU to select it. 5. Press Volume down Key to scroll to Yes -- delete all user data and press MENU to select it. 6. After the data wipe is complete, press the down Volume Key to scroll to reboot system now and press MENU to select it.
11/6/2017 2:14:50 AM • LG Optimus... • Answered on Nov 06, 2017
How do I change the SD card
Removing the microSD Card To safely remove the microSD card from your device, you first need to unmount it. WARNING: On the Android OS 2.3, you can download applications from Android Market and store them on a microSD card as well as on the device. Due to this feature, skipping the unmount procedure can cause an error because information between the microSD card and the device is not accorded properly. In the worst case, the microSD card can be corrupted or damaged. 1. Press > > Settings>Storage>Unmount SD card. Confirm your selection by tapping OK.Now you can safely remove the microSD card. 2.Remove the back cover using the fingertip cutout at the bottom of the cover. 3. Gently press the microSD card in to release it and carefully pull it out of the slot. Inserting the microSD Card 1. Remove the back cover using the fingertip cutout at the bottom of the cover. 2. Position the microSD card with the label side facing up and slide it into place until it is fully inserted and locked in place. Note Be sure to use only recommended microSD cards (up to 32GB). Using non-recommended microSD cards could cause data loss and damage your device
10/19/2014 8:58:05 AM • LG Optimus... • Answered on Oct 19, 2014
Lgl55c
Hello:defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will Solved
2/9/2013 11:14:39 AM • LG Optimus... • Answered on Feb 09, 2013
Lg fb163-how to add bluetoth function
To add Bluetooth functionality to your LG FB163, you can use a Bluetooth adapter that is compatible with the device. Ensure that the adapter you choose is compatible with the FB163 model. Once you have the adapter, follow the instructions provided with it to connect it to your FB163 system.
To connect your Android phone to the FB163, you'll need a compatible cable. Typically, you would use an auxiliary (AUX) cable with a 3.5mm jack on both ends. Plug one end into the headphone jack of your Android phone and the other end into the AUX input port on the FB163 system. Then, select the AUX input mode on the FB163 to hear the audio from your phone through system.
3/11/2024 11:43:44 AM • LG Cell Phones • Answered on Mar 11, 2024
How to unlock wheels on LG refrigerator - model LMXS27626S
The wheels have no locks on them. If you want to use the wheels you have to screw in the feet. https://www.google.com/search?q=LG+refrigerator+LMXS27626S.+How+to+unlock+the+wheels ..
2/19/2024 5:38:48 PM • LG Cell Phones • Answered on Feb 19, 2024
2answers
How can I hatd factory hard reset my LG 265 if I don't have my pin # nomore or forgot it .
  1. Turn the phone off.
  2. Press and hold the Power/Lock key (on the right side of the phone) and the Down Volume key (on the left side of the phone) at the same time.
  3. When the Factory data reset screen appears, release both of the keys.
  4. Use the Volume keys to highlight Factory data reset, then press the Power/Lock key to confirm.
  5. Use the Volume keys to highlight Yes, then press the Power/Lock key to confirm one more time.
  6. Your phone will perform a factory reset.
2/3/2024 11:11:02 PM • LG Cell Phones • Answered on Feb 03, 2024
How to I factory reset a LG Android Phone. I forgot the code to the screen lock
Hi, The link below is a short youtube video showing how to factory RESET your phone....CHEERS.. How To Hard Reset LG G4
2/3/2024 10:59:49 PM • LG Cell Phones • Answered on Feb 03, 2024
5answers
How do I recover phone history from my phone that
When files are "deleted" they are not actually removed from your iPhone, until something else overwrites them. So by saving anything else to them you may have overwritten them. There is a decent chance that you can restore lost data of iPhone though. I've successfully used undeleted plus before to restore iPhone history that were accidentally deleted on my iPhone. Give it a shot and good luck.Read more: http://www.recovery-ipad.com
1/10/2024 1:36:33 PM • LG Cell Phones • Answered on Jan 10, 2024
Plz help my phone LG GS170 its imei 012201001451683 need unlock code
Contact your service provider.
12/30/2023 3:02:29 PM • LG Cell Phones • Answered on Dec 30, 2023
Where does the SIM card go on a LG LS670 phone?
Question edited for clarity and typo. It takes a Micro SD Card in the upper right edge. Page 12 of the Manual shows it. https://www.lg.com/us/mobile-phones/pdf/LS670_%20Optimus_S_UG_1.1.pdf https://www.google.com/search?q=lg+ls670+insert+micro+sd+card ..
11/30/2023 9:43:24 PM • LG Cell Phones • Answered on Nov 30, 2023
LG G7 ThinQ. It won't connect to my Bluetooth touchscreen.
Question edited for clarity. The problem here is not knowing what the 'Bluetooth Touchscreen' is on? This is normally an issue shaking hands to complete the connection. https://www.fixya.com/support/r26362721-pairing_bluetooth_devices ..
11/25/2023 8:05:58 PM • LG Cell Phones • Answered on Nov 25, 2023
MY LG PIN IS BLOCKED. How do I go about it?
Question edited for clarity, I presume you meant LG not 'PG'? It sounds like it is PUK Locked, also known as a SIM Lock. https://www.fixya.com/support/r26056685-phone_asking_puk_code and in simpler terms https://www.fixya.com/support/r26230986-phone_asks_puk_code_ask_another_way ..
11/22/2023 8:56:12 PM • LG Cell Phones • Answered on Nov 22, 2023
3answers
LG LH-T7650 DVD Receiver turned off after I insert a USB drive.
The USB socket is for reading multimedia USB Memory. Your phone has power in it. Not sure how that would work. Page 5 https://manualzz.com/doc/49428761/lg-lh-t7650x-owner-s-manual ..
5/20/2023 1:02:20 AM • LG Cell Phones • Answered on May 20, 2023
2answers
Im locked out of my
WARNING : Performing a hard reset will remove ALL data including the Google account, system data, application data, application settings, and downloaded applications.
  1. With the phone off, press and hold the Home key, Volume Down key and Power button. When the LG logo appears, release only the Power button.
  2. Release the Home key and Volume Down key when the Android icon appears.
  3. Follow the on-screen instructions.
4/1/2023 11:47:35 PM • LG Cell Phones • Answered on Apr 01, 2023
Can an LG Stylo 4 with a cracked screen , showing only a black screen be repaired so i may extract data from it ?
It is possible to repair an LG Stylo 4 with a cracked screen that shows only a black screen to extract data from it. However, the success of the repair will depend on the extent of the damage to the screen and other internal components.
You can take your device to a professional phone repair shop and ask them to repair the screen. Once the screen is repaired, you should be able to access your data on the device. If the screen repair is not possible or too expensive, you may be able to extract data from the device by connecting it to a computer with a USB cable and using a data recovery software.
Note that data recovery software may not be able to recover all the data from the device, especially if the device has suffered significant damage. It's always a good idea to regularly back up your data to avoid losing important files in case of accidents or device failure.
3/17/2023 12:51:52 AM • LG Cell Phones • Answered on Mar 17, 2023
How come after I take a picture on my LG ENV3, it does not save?
Could be saving to a memory card!
Check settings to see where the photos are being stored!
2/22/2023 11:39:42 PM • LG Cell Phones • Answered on Feb 22, 2023
LG Optimus Slider Logo
16 questions posted
Top LG Cell Phones Experts
vince
Steve Sweetleaf
Steve Sweetleaf
nexrad_chris
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
LG Cell Phones
  • LG Cell Phones
Most Popular Question
need unlock locked lgl55c
  • Cell Phones
