20 Most Recent Digihome LCD TV Questions & Answers
3answers
My Digihome tv 32913LCDDVD is stuck in standby
Count the number of flashes occur at one time switch ON. These flashes are called blinking codes; and are fault indications. Form the number of these blinks, you can get an idea about the faulty circuit stage inside the TV. If you wish to get more details about these blinking codes, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
4/1/2021 2:18:41 AM • Digihome LCD TV • Answered on Apr 01, 2021
2answers
When I connect my USB I get an invalid or Unsupported format for videos? why?
Because the format of the video is invalid or unsupported by the video player.
12/29/2020 4:01:36 PM • Digihome LCD TV • Answered on Dec 29, 2020
How to get movies to work when using external hard drive
Try download a converter on the USB storage it's the tv it can't read the file
11/30/2019 1:10:43 PM • Digihome LCD TV • Answered on Nov 30, 2019
DIGIHOME 40" LED TV. Model is 40272SMT2 FHD LED. Blue tint all over screen.
Hey Noel, that is just a T-com board problem. Replace the T-com board.
8/20/2019 3:30:25 PM • Digihome LCD TV • Answered on Aug 20, 2019
3answers
I have digihome tv has sound but no picture and nothing on virgin
is this happened either watching a tv channel or even watching dvd movies?. and then does the display only white screen or a totally black screen?.
6/17/2019 6:51:25 PM • Digihome LCD TV • Answered on Jun 17, 2019
No picture on HDMI channel on my digihome 22784WHD
sound no picture
5/5/2019 6:41:35 PM • Digihome LCD TV • Answered on May 05, 2019
The TV wont turn on, no red light, nothing happens
Bad SMPS
12/31/2016 7:44:56 PM • Digihome LCD TV • Answered on Dec 31, 2016
My Digihome Smart TV has currently gone into a blank grey screen, it will not work with the remote and the sound isn't working and it's saying its on but it isn't responding, what should I do?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
9/16/2016 3:06:25 AM • Digihome LCD TV • Answered on Sep 16, 2016
DVD player on my digihome TV is not working
Go to digihome support to get the Manuel
8/26/2016 11:26:41 PM • Digihome LCD TV • Answered on Aug 26, 2016
Black and white
Yes your player has gone into a wrong region make sure that if your tv is pal it must be pal NTSC will also make it go black and white check tv input and DVD player settings
8/26/2016 11:19:47 PM • Digihome LCD TV • Answered on Aug 26, 2016
My Digihome 39180SM FHD LED TV will not go past the standby stage. It is brand new and it will not turn on to reach first time installation.
Take it back it's still in warranty it's the power supply problem
8/26/2016 11:14:31 PM • Digihome LCD TV • Answered on Aug 26, 2016
Tv will not switch on
You probly got the button wet you will havev to try use a hair dryer in the eges and blow it dry or you have poped a fuse pop the back of look for a glass tube fuse it's only 1cm big it could also be white just check it will cost about 1 dollar for the fuse
8/26/2016 11:13:25 PM • Digihome LCD TV • Answered on Aug 26, 2016
When on standby my tv turns itself on Ive had to turn the sound down. Now I have to pull out the plug, there is no particular time this happens can you suggest anything?
There might be someone around you with a similar tv or do you have a other one in the house some people use remote blasters and that can also transmit a far distance just close the ir in front of the tv
8/26/2016 11:09:30 PM • Digihome LCD TV • Answered on Aug 26, 2016
Can u get surround sound to play on Normal TV channels it's digihome 50" led smart TV
Sure are you using a preamp component system or do you want to play it on the tv if you do have a pre amp run the RCA cables to sterio input on amp or aux then in the setting of the amp go into sound and put the aux to 6.1 also remember that to use audio out on your tv
8/26/2016 11:06:40 PM • Digihome LCD TV • Answered on Aug 26, 2016
How do you put on the 3D
In setting you must be in user not auto then swop from 2 to 3 d
8/26/2016 11:02:42 PM • Digihome LCD TV • Answered on Aug 26, 2016
Brand new tv and when I switched it on there is a huge black area shaped like a hill coming from the bottom half way up my screen - no sound
return for replacement or repair if try to repair or tinker with will void any warranty or return policy
8/16/2016 12:03:32 PM • Digihome LCD TV • Answered on Aug 16, 2016
Tv indicates no signal why?
Mine is the same, i think it is because it is in analogue mode and I can't switch it back. Did you get anywhere?
2/15/2016 9:43:22 AM • Digihome LCD TV • Answered on Feb 15, 2016
Digihome LCD TV Logo
160 questions posted
Top Digihome Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Digihome Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Digihome Televison & Video
Most Popular Question
digihome 40 led tv model 40272smt2 fhd
  • Televison & Video
