20 Most Recent Tevion AP-DVR18 DVD Recorder Questions & Answers
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Tevion AP-DVR18... | Answered on Aug 26, 2017
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
If you wish to get some details; visit the site linked here. Pull up older posts.
Firmware (Software) update procedure of many popular brand TVs and other devices are given in detail.
If the recorder is old the analogue/digital change is screwing it up. It isn't the TV that is the problem, it is the received signals, but the problem is the same.
Tevion AP-DVR18... | Answered on Dec 28, 2013
I was unable to find the manual but you can refer to the link below for some guidance:
http://www.fixya.com/support/t15493826-set_time_tevion_alarm_clock
Hope this helps.
Tevion Televison... | Answered on Oct 28, 2019
Google (tevion)(TEV605)(manual) without parens for instructions.
Tevion Televison... | Answered on Jul 11, 2019
You can finalise any disk on a computer as this will close out the session and make it playable. If you software wont directly let you directly finalise it, then copy the files to the computer and then burn them as a video disk. Nero will do this.
Tevion Televison... | Answered on May 24, 2019
SAD BUT FIXYA CAN NOT ASSIST YOU WE DO NOT SELL PRODUCTS HERE
Tevion Televison... | Answered on Apr 10, 2019
it might be that all you have are not from the proper region
Tevion Televison... | Answered on Apr 02, 2019
Tevion AP-DVR18 DVD Recorder Logo
10 questions posted
Top Tevion Televison & Video Experts
Pcm2048
 Grubhead
Grubhead
James
Are you a Tevion Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Tevion Televison & Video
Most Popular Question
flashing green ligh
  • Televison & Video
