20 Most Recent
NEFF S54T09X1GB Fully-Intergrated Full Size Dishwasher Questions & Answers
My NEFF integrated dishwasher will not fill
It sounds like there may be an issue with the control board or programming of your NEFF dishwasher. The fact that the impeller runs and the rotor arms spin when water is manually added to the sump, but the controller does not call for water when the sump is empty suggests that there is a problem with the communication between the control board and the water inlet valve.
The round white device you mentioned that is located in the water inlet before the water inlet valve is likely a flow meter. It is used to measure the amount of water flowing into the dishwasher and send a signal to the control board to indicate when the appropriate amount of water has been reached. This device could be malfunctioning and preventing the control board from requesting water.
It's also possible that the problem is with the level float and plunger that operate the micro switch you mentioned. If the float and plunger are not working correctly, the control board may be receiving incorrect information about the water level in the sump and preventing the dishwasher from filling with water.
It is best to check the user manual for the dishwasher, it will have the troubleshooting section, you can try the solution mentioned there. If the problem persists, it is best to contact NEFF customer service or an appliance repair professional for further assistance.
Neff Integrated Dishwasher. The pump on my dishwasher won't stop running!
That is the classic behaviour of a flood sensor being wet. You said 'anti flood float'. I know them as a small sensor in a tray under the machine and above the floor in a plastic pan. If it is that where your float is, then you need a service call to diagnose. It is likely to be a circuit board issue and they are expensive so need proper eyes-on trained diagnosis.
My Neff dfn60 dishwasher has no power
I suggest looking under the sink. Some dishwashers simply are plugged into an outlet under the sink.
It very well could have came unplugged.
If that isn’t what it is most likely a breaker has tripped in your breaker box. Try to identify the tripped breaker. Switch to the left and then to the right. Check and see if you now have power.
If neither of these, I would suggest calling a appliance repair technician.
I hope this information helps. Have a blessed day!
