20 Most Recent
Kenmore 665 Questions & Answers
Kenmore Elite 665.13443K901 model number. The detergent cup is not opening.
A new model DISHWASHER CAR.
If the detergent cup on your Kenmore Elite 665.13443K901 dishwasher is not opening, there could be a few different reasons. Here are a few things you can try to troubleshoot the problem:
- Check the detergent cup: Make sure that the detergent cup is not jammed or clogged with detergent.
- Check the detergent dispenser: Make sure that the detergent dispenser is not clogged or malfunctioning.
- Check the control board: Make sure that the control board is not malfunctioning.
- Check the timer: Make sure that the timer is set correctly and that it is not stuck in a continuous loop.
- Check the door switch: Make sure that the door switch is not stuck in the closed position.
- Check the wash impeller: Make sure that the wash impeller is not clogged or malfunctioning.
- Contact Kenmore customer support: If you have tried all the above steps and the dishwasher is still not working, it may be best to contact Kenmore customer support for further assistance. They will be able to diagnose and fix the issue or tell you if a repair is needed.
1/23/2023 6:48:24 PM •
Kenmore 665
Answered
on Jan 23, 2023
Why are all lights staying on kenmore ultra wash dishwasher 665
I'm not sure if all of your lights are staying on, but if it is several at least and your cycle is done....just push your door closed again and the lights should go out. I find that after my cycle finishes, if I don't completely close the door, most of the lights stay lit. I have to be sure the door snaps in all the way when I close it or the lights stay on.
7/28/2014 6:17:25 AM •
Kenmore 665
Answered
on Jul 28, 2014
How do to get my dishwasher running like normal again?
I don't see the connection between the heating element and a load indicator malfunction. I had a Kenmore that needed a new computer board a long time ago. The heating element is simply a heater. Depending on your finances, it may be cheaper to pull the dishwasher and take it to a repairman to diagnose the problem. He can replace the computer board for a lot less than the cost of a new washer. Hope this helps.
7/6/2014 10:54:37 PM •
Kenmore 665
Answered
on Jul 06, 2014
My kenmore dishwasher not working code f4e1 came on
I checked the searspartsdirect.com website, and according to them, it is a 'motor communication issue.' In order to get more details, you have to create a login, and it was taking forever to complete that, so I gave up.
Try flipping the circuit breaker, leave it off for 1 minute, then turn it on again. Do you still get the error code?
Okay, I finally completed the sign-up process. Here is some more info from an actual repair technician:
The F4E1 is a code that signifies a WASH MOTOR
issue. Specifically, no Communication. This is usually caused by: A loose connection in Wash Motor Circuit, Motor Communication Circuit and/or an open wash motor. 1. Unplug dishwasher or disconnect power. 2. Check all connections in Wash/Rinse Circuit and Motor Communications Circuit with meter. Fix/replace an open connection/part. Motor fuse on control open. 1. Start Service Diagnostics Cycle using keypad and advance through the error code intervals to interval 19. ( shown on image below ) 2. Listen for 2 relay contact clicks at the start of interval 19 (to confirm both the pilot and motor relays are turning on.
NOTE : These relays provide power to the motor, but the motor does not start until it receives a start command later in the cycle). If hear only 1 or zero clicks and wash motor does not come on later in service cycle, and there were no loose wire communication wire connection when checked above, then unplug dishwasher or disconnect power and replace control.
Faulty wash motor. 1. Unplug dishwasher or disconnect power. 2. Use inspection mirror to inspect for water leakage and/or overheating on the wash motor. If evidence of overheating exists, replace wash motor. If evidence of moisture exists, check seals and hoses.f you do not feel confident repairing this problem yourself, then you can have it repaired at your home by a Sears technician. Here is a link for the website:
6/12/2014 6:07:20 AM •
Kenmore 665
Answered
on Jun 12, 2014
Dishwasher f4e1
This is an error that means the controller is not talking to the motor. You need to check the connections on the motor
2/13/2014 2:20:36 AM •
Kenmore 665
Answered
on Feb 13, 2014
Dishwasher won't run. Worked yesterday, checked curcuit breaker, ok. water is in the bottem of washer but below the float level.
First, check the dishwasher filter and make sure it isn't clogged. Your owner's manual will have simple instructions on how to access and clean your dishwasher's filter. Next, check the drain hose. Does it look flattened or kinked? Do you see any sharp bends? If so, straighten out the hose with your hands and manipulate it so that it regains its rounded shape.If your dishwasher drains through the garbage disposal, try running the garbage disposal for a bit to process and clear any food. If that does not get the machine draining, you may have a deeper clog. However, most drain hoses clog either at the main household sink drain line connection or the garbage disposal connection.Does your dishwasher spray your dishes, but it does not advance to the next stage and drain the dirty water? The timer controls the start of the draining process, so you may need an entirely new timer or a new motor for the timer. Repair service is recommended.In some dishwashers, standing water is caused by a valve that fails to open and allow the water to drain out. This valve is controlled a solenoid that the timer controls. A malfunctioning solenoid could be the problem. For more troubleshooting tips and solutions, see
Dishwasher not draining. I hope this helps!
9/28/2012 10:37:06 AM •
Kenmore 665
Answered
on Sep 28, 2012
