20 Most Recent
Yamaha Wave Runner GP 800 Questions & Answers
Jet pump 1 and 2 starts. Try and start jet 3 you hear a click
Relay is shot... the click is the low voltage circuit closing the switch but the power isn't traveling through the high side. Relays are cheap ... if you have an old junk car lift the hood open the fuse box on the drivers side it is loaded with little square relays. . . The idea is the switch isn't supposed to have large amounts of power flying through it so they place a relay which is a magnetic switch away from the use... when you activate it the magnetic current runs through the iron in the switch and it closes the circuit.
How do I check the oil pump on a 96 wave runner 760 twin carb
First, empty your fuel tank and pour a 2% fuel mix in it.
Remove the oil hoses coming to the carbs. Put the ends in 2 recipients.
Run the engine for a few minutes. Oil must come in the recipients. I couldn't find an exact quantity in the Service manuals.
The theoretical mix is 50:1 ( 50 liters fuel with 1 liter oil)
So, the best way is to have a full tank 50/1 fuel/oil mixture AND a full oil tank.
Sail a few hours, refuel ( count how many liter you've burned. Refill the oil tank to level.
Check that the fuel/oil ratio is about 50:1.
You can adjust the mixture with the cable on the oil pump.
