20 Most Recent
Kodak Easyshare C183 Questions & Answers
Kodak easy share c183 memory card protected how to reset
support.en.
kodak.com/.../camera-lcd%3A-
memory-
card-is-
protect...
KodakAug 25, 2010 - The camera screen displays "Memory card is protected (Reset switch on card). ... The memory card is locked so that data (pictures, videos, or files) ... The disk is write protected." when writing to or formatting an SD card. Share.
resources.
kodak.com/support/pdf/en/
manuals/.../
C183_xUG_GLB_en.pd...
Kodak, EasyShare, Max, Perfect Touch, and Pulse are trademarks of Eastman Kodak. Company. ..... Access to more manual settings than Smart Capture mode. ..... NOTE: To delete protected pictures/videos, remove protection before deleting.
Sd card won't click down
There may be several reasons.
1. Is the SD card the right size? Check to confirm your card is the right size for the camera.
2. Make sure you face the card the right way. If you try inserting the wrong-way, it won't slide into its compartment.
3. Check to make sure that the sliding switch on the card is aligned to 'ON'
4. Make sure the card compartment is free from obstruction
When you try the 4 points above but cannot slide the SD card into the camera, let me know.
Free download software
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program, such as the free Picasa (
http://picasa.google.com ).
Memory card protected reset switch
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
C183 cant download
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as
Picasa.
Kodak easyshare TURNS OFF when pluged into the pc!!!
Try NOT plugging your camera into your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as
Picasa.
