20 Most Recent Cub Cadet z-force 60 Questions & Answers
2answers
I have a 50 in z force mower and the steering handles overlap about 2 in. Can I adjust the side to side slop ?
not car or truck, and is CUB CADET Z-FORCE 50LAWN MOWER,MOVED YAH/I moved you from cars to mowers.moved you!
6/1/2023 8:11:49 PM • Cub Cadet... • Answered on Jun 01, 2023
2answers
How to replace mower belt for ZTR cub cadet mower
Changing the Blade Drive Belts: a.Set the parking brake. Remove ignition key and both spark plug caps. b.Unscrew the wing nuts from the deck covers and remove both covers. c.Using a 3/8" socket breaker bar or socket ratchet insert the drive end into the 3/8" square opening in the lower idler arm assembly and push the idler arm counterclockwise. While holding the idler arm back, loosen the blade drive belt from the pulley and slide the belt away from the pulley. d.Remove tension of the PTO belt by moving the belt tensioning rod. Loosen the belt retaining bolt. e.Pull the tensioner pulley away from the belt and remove the PTO belt then remove the blade drive belt. f.Reverse the process to install the belt. 25361151-qu4ydggxxtbusm5ukn0js34e-2-0.png
1/8/2015 10:59:27 PM • Cub Cadet... • Answered on Jan 08, 2015
0answers
Wont start
Be the first to answer 4/16/2014 4:31:11 AM • Cub Cadet... • Posted on Apr 16, 2014Be the first to answer
How do I reset the clean air filter warning on my cub cadet LT42
It's a 50 hour service reminder that will auto reset after 7 minutes (engine running).
3/14/2024 5:03:29 AM • Cub Cadet Garden • Answered on Mar 14, 2024
Cub Cadet 1050 2014 model. The gas pedal locks in the down position until engaging the break.
If the gas pedal on your 2014 Cub Cadet 1050 model is locking in the down position until the brake is engaged, there may be an issue with the mower's safety interlock system. This system is designed to prevent accidental engagement of the blades when the operator is not in control. Check for any debris or obstructions around the pedal mechanism and the brake system. Additionally, inspect the safety interlock switches near the brake pedal for proper function. If the issue persists, it's recommended to consult the owner's manual for troubleshooting steps or seek assistance from a qualified Cub Cadet service professional to ensure safe and proper operation.
1/28/2024 11:39:47 AM • Cub Cadet Garden • Answered on Jan 28, 2024
Cub cadet chipper shredder starter coil is locked - will not pull
Recoil starter is locked?Remove spark plug to be sure engine hasn't hydrolocked with fuel and/or check crankcase oil level. If excessively high oil level then likely crankcase and cylinder is full of fuel from a stuck carburetor fuel inlet needle valve.If cylinder is clear of fuel/oil then remove recoil starter and see if recoil is functional and engine will rotate by hand.
12/6/2023 8:03:07 PM • Cub Cadet Garden • Answered on Dec 06, 2023
Need wiring diagram for cub cadet mod 13bx11cg712
https://www.ccpartsnmore.com/uploaded/files/cub-wire-schematics/cub-lt-tractor-wiring/LT%201042%20%282005%29.pdf
11/29/2023 12:17:27 AM • Cub Cadet Garden • Answered on Nov 29, 2023
Cub cadet lxt 1046 throttle cable how to change
For the most accurate and up-to-date information, I recommend consulting the official Cub Cadet LXT 1046 operator's manual. The manual typically includes detailed instructions on maintenance procedures, including how to replace components like the throttle cable.
11/15/2023 2:05:46 PM • Cub Cadet Garden • Answered on Nov 15, 2023
I need a size replacement belt number cub cadet deck belt
Hey, I gave you all this information yesterday! The answer doesn't change because it is a different day. Stop hiding behind 'Anonymous', it is hardly a secretive post! https://www.fixya.com/support/t29936480-size_belt_replacement_sears_2000_cub The SV 590 is the model designation of the Kohler engine powering the lawn tractor. https://www.google.com/search?q=kohler+model+sv590s+parts+diagram The 'Sears 2000 Cub Cadet' part is most of your tractor model details and the Deck Belt appears to be 42". https://www.google.com/search?q=Sears+2000+Cub+Cadet+deck+belt ..
10/15/2023 2:27:18 AM • Cub Cadet Garden • Answered on Oct 15, 2023
2answers
What size belt replacement for Sears 2000 Cub Cadet deck belt model SV 590?
10/14/2023 3:28:00 AM • Cub Cadet Garden • Answered on Oct 14, 2023
Cub cadet hydro 1320 starts but won't stay running longer than a few minutes. Fuel is good?
i dont know nothing about the cub cadet but if its doing that i would change the camshaft positioning sensor
9/6/2023 9:56:15 PM • Cub Cadet Garden • Answered on Sep 06, 2023
Cub Cadet with Onan 14hp . PTO clutch and PTO engagement switch both new. PTO clutch disengages whenever it wants. Cold or hot. Charging system issues? How to info check and what to look for?
The clutch likely has an adjustable air gap that requires adjustment. The procedure will be outlined in the model service manual. Typical gap is 0.015"
8/29/2023 8:15:32 PM • Cub Cadet Garden • Answered on Aug 29, 2023
20 amp fuse keeps blowing when engaging PTO, cub cadet ZT1 54 (model 17AREACA010)
Disconnect the voltage regulator and replace the fuse. If the fuse doesn't blow then likely the regulator was damaged and will need replaced.
8/29/2023 10:32:09 AM • Cub Cadet Garden • Answered on Aug 29, 2023
We have a 1986 Cub Cadet Hydro 1210 that won't go forward!
If your 1986 Cub Cadet Hydro 1210 is experiencing difficulty moving forward but works fine in reverse even after changing the transmission filter and fluid, there could be a few potential reasons for this issue. Here are some steps you can take to troubleshoot the problem: 1. **Check Drive Belt:** The drive belt is responsible for transferring power from the engine to the transmission. A worn or damaged drive belt can affect forward movement. Inspect the drive belt for any signs of wear, fraying, or damage. If the belt is in poor condition, consider replacing it. 2. **Check Tension of Drive Belt:** Ensure that the drive belt is properly tensioned. A loose drive belt can lead to slipping and difficulty in forward movement. Adjust the tension according to the manufacturer's specifications. 3. **Inspect Linkage and Connections:** Examine the linkage and connections between the control lever, transmission, and the drive system. Loose or misaligned linkage can result in improper engagement of gears, affecting forward movement. 4. **Hydrostatic Transmission Issues:** Since your Cub Cadet Hydro 1210 uses a hydrostatic transmission, there could be issues with the hydrostatic unit itself. Check for any signs of leaks, damaged hoses, or worn components in the hydrostatic transmission system. 5. **Transmission Oil Level and Quality:** Ensure that the transmission oil level is correct and that you're using the recommended type of oil. Poor-quality or incorrect transmission oil can lead to performance issues. 6. **Air in the Hydraulic System:** If there's air trapped in the hydraulic system, it can cause issues with the hydrostatic transmission. Bleed the hydraulic system to remove any air bubbles. 7. **Transmission Pulley and Sheaves:** Check the transmission pulley and sheaves for wear or damage. If these components are not functioning properly, they can affect the movement of the drive belt. 8. **Check for Obstructions:** Inspect the underside of the mower deck and the drive system for any debris, obstructions, or objects that might be interfering with the forward movement. 9. **Professional Inspection:** If none of the above steps resolve the issue, it might be a more complex problem requiring the expertise of a professional technician. They can perform a more in-depth diagnosis of the hydrostatic transmission system and identify any underlying issues. Keep in mind that working with mechanical and hydraulic systems requires knowledge and expertise. If you're not comfortable performing these checks and repairs yourself, it's recommended to consult a qualified technician who has experience with Cub Cadet or similar equipment.
8/26/2023 10:16:07 AM • Cub Cadet Garden • Answered on Aug 26, 2023
Garden Logo
Popular Tags
14 questions posted
Top Cub Cadet Garden Experts
john h
Steve Sweetleaf
Steve Sweetleaf
Daniel Blask
Daniel Blask
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
View Most Popular
Cub Cadet Garden
  • Cub Cadet Garden
Most Popular Question
50 in z force steering handles overlap
  • Garden
