20 Most Recent
FIRST Alert 2754DB Executive Fireproof Gun Safe Questions & Answers
Replace elctronic key pad fr tumbler lock
Unfortunately most safes cannot be converted from an electronic keypad to a dial lock. Those that can be are specific to the type of lock i.e. type 1, type 2 etcetera. I had the same problem with my safe where the keypad would accept the code but not open the lock so I had to use the key. I contacted the manufacturer and found that the circuit board was faulty and they sent me a new improved version for free. Your safe has a five year warranty and even if the warranty has expired I would contact First Alert to see if they can remedy your dilemma. They would also be able to advise you if your keypad can be converted to a dial lock. If it can be converted I would recommend having it installed by a certified locksmith that guarantees their work.
Repair the power supply of a security system
Today I have repaired an AC adapter which 12 volts and 5 amps, the user first wanted his system box at the garbage place I know that the little system usually nothing wrong degree but the food is glued shut, but 99% of all cases it is internal to these power adapters there are usually two broken capacitors, it is precisely because these surveillance systems are often 24 hours a day to stand. the capacitor capacitance no automatic self-healing cap form one of them was leaking and the other was topped convex. The plastic house can be opened with a bench hammer on the glued seam around rapping and then you can usually afterwards the affair glue with superglue. expenses was less than 2 euros a number of capacitors bought at a dump is very convenient. So first of all, remember that you can often restore the power adapter easily. and not quickly conclussie pulls the basic device for camera surveillance is defective which is usually thought to be something wrong degree.
My doorbell has gone quiet
It may have this silent option in either choice for volume or melody. My doorbell has numbered buttons that need to be pressed together with the button to open the door, in order to access these functions.
Another thought is that a battery needs to be replaced.
