20 Most Recent Gateway Wireless-G PC Card (6002547) Questions & Answers
Wireless internet
The 3G mobile internet adapter is a small dongle that you need to plug into a computer.
The software setup is often automatic, and software will be installed by the dongle itself.
After installing you will need to pay for internet traffic, either with a contract and monthly fee, or with a pay as you go contract.
Fees vary depending on your country and on companies.
Here is an example of 3g adapter for UK MOBILE BROADBAND MODEM HUAWEI DONGLE 3G USB MODEM.
Better to buy adapter, sim card, and eventually cotract all from same company at a shop.
2/10/2009 3:26:37 PM • Gateway... • Answered on Feb 10, 2009
I have the application SuperSU the free edition on my phone and everytime I try to use it to root my phone forwards me to an address on Chrome the simply says 502 bad gateway
you can use kingroot to root your phone. and some root apps might harm yor os i suggest you not to root your phone
3/1/2024 4:28:21 PM • Gateway... • Answered on Mar 01, 2024
I have a Gateway LP2417 monitor and there's No sound.Hoe do I fix it,so I can hear the video that is playing?
This monitor may not have built-in speakers. It may have supported Gateway's monitor mounted sound bar. That sound bar connected to the 3.5 mm audio out on a computer and a DIN port on the monitor. The simplest solution is to connect your source to appropriate speakers. Depending on your audio setup, you could connect the video source to a receiver with HDMI IN and HDMI Out (ARC), computer speakers or an audio extractor. (If you are using an HDMI cable between the Gateway LP2417 and a computer, you may need to reset the audio output to use basic computer speakers (3.5mm jack).) VGA and DVI connections don't support audio so I assume you are using the HDMI port. I hope this helps. Cindy Wells
1/18/2024 10:32:24 PM • Gateway... • Answered on Jan 18, 2024
I have a gateway Zx4931 and the power button is not working. Do I need to replace the power button or can I reconnect the wires?
Re connecting the wires may work without issues.
12/26/2023 5:46:39 PM • Gateway... • Answered on Dec 26, 2023
Do i need a driver for old gateway gmax2000 speakers connected to an old acer-based home built pc my nephew gave me?
No you don't need a driver. These are very plain powered speakers that come with a mains adapter and a lead with a 3.5mm stereo jack at both ends. Plug one in the speaker and the other into the headphone jack on the front or the speaker socket on the back which will either be a socket on the motherboard, or if your son put a sound card in the computer, it will be in a sound card. If it doesn't play straight away, go into Settings - Audio and make sure the sound card or the On-Board Audio is enabled. This shows the cable https://picclick.com/Vintage-Gateway-2000-ACS41-Altec-Lansing-Multimedia-Computer-314990339798.html#&gid=1&pid=1 More here https://www.google.com/search?q=gateway+gmax2000+speakers ..
11/29/2023 12:20:06 AM • Gateway... • Answered on Nov 29, 2023
WATTS REQUIRED FOR GATEWAY LAPTOP NV55C
110 watts for the power supply.
11/21/2023 1:16:48 AM • Gateway... • Answered on Nov 21, 2023
Wiring diagram for LX6200-01
10/30/2023 11:58:58 PM • Gateway... • Answered on Oct 30, 2023
How to make touch screen on gateway computer upside down and how to put it back?
f you want to use your touch screen on your gateway computer in an upside down orientation, there are a few things you need to do. First, you need to change the orientation of the screen in the control panel. To do this, go to the control panel and select "Display." Next, click on the "Settings" tab and then click on the "Orientation" drop-down menu. Select "Landscape (flipped)" from the menu and then click on the "Apply" button. Now that the orientation of the screen has been changed, you need to adjust the position of the touchscreen so that it is in the correct position. To do this, go to the control panel and select "Hardware and Sound." Next, select "Pen and Touch" and then click on the "Calibrate" button. Follow the on-screen instructions to calibrate the touchscreen. Once you have finished, the touchscreen should be working correctly in the upside down orientation. I hope this helps!
3/14/2023 5:41:18 PM • Gateway... • Answered on Mar 14, 2023
I have a Gateway Laptop that on startup only goes to the configuration screen. It won't boot Windows at all
They deleted the Operating System by deleting their own stuff Docs, images, Saved Links etc. and also everything in Windows System probably in spite. You need to reload the operating system (Win 11) from fresh. Charge them from their final pay check, or ask IT to do it.
3/1/2023 1:19:14 AM • Gateway... • Answered on Mar 01, 2023
2answers
Gateway / Packard Bell EASYNOTE MS2291 Laptop will not start.
Question edited for a lot more clarity, FULL 'make, model (what it is)'. Question moved from 'Power Computers'. Connect a computer monitor to the port on the back. When I Google the model number the first thing that shows is Replacement LCD Screens for it which leads me to believe there is an issue with them. There is three parts to the display, the video card section, the exciter module and the screen itself. It needs correct diagnosis, or buy a new one now you have reset it clean, if that is what you mean by 'hard restart'? You might mean 'hard boot', power off and back on without proper shutdown. That is bad for the OS. https://www.google.com/search?q=Model+MS2291 Keyboard shortcuts for shutdown
How to Shut Down or Sleep Windows 10/11 With a Keyboard ...
https://www.makeuseof.com > Windows 1. Use the Power User Menu Shortcut · Press U again to shut down Windows. · Hit the R key to restart. · Press S to put Windows to sleep. · Use H to hibernate. · Hit ... Sleep Mode Issues · ‎Establish a hotkey · ‎Guide to hibernation on.....
2/26/2023 8:34:30 PM • Gateway... • Answered on Feb 26, 2023
I have a 2017 Gateway All in One Pentium Model zx6980 Push power button monitor comes on faintly No signal HD something. Will not boot
It sounds like there could be a few different issues going on with your computer. Here are some steps you can try to troubleshoot the problem:
  1. Check the connections: Make sure all cables and connections are secure and properly plugged in. This includes the power cable, monitor cable, and any other peripheral cables.
  2. Check the monitor: Try connecting your computer to a different monitor to see if the issue is with the monitor itself. If the other monitor works, the problem is likely with your original monitor.
  3. Check the hard drive: Disconnect the new SSD hard drive and try booting up the computer without it. If the computer boots up successfully, there may be an issue with the hard drive or its installation.
  4. Check the battery: As you mentioned, the issue could be related to the battery on the motherboard. Try replacing the battery with a new one and see if that helps.
  5. Try booting into safe mode: If the computer is still not booting up, try booting into safe mode by pressing the F8 key during startup. This will allow you to troubleshoot any issues with your computer's software.
If none of these steps resolve the issue, you may need to take your computer to a professional for further diagnosis and repair.
2/26/2023 7:02:04 PM • Gateway... • Answered on Feb 26, 2023
What is the max ram I can install on my Gateway MA 3?
Pull up a RUN box. Windows key plus R. Then type in cmd and hit enter. Next, using the command prompt that has appeared, type in wmic memphysical get MaxCapacity, MemoryDevices Hit enter. Copy the number you see and devide that by 1048576 You can actually do that in the address bar of your browser. That will give you the maximum gigabytes your computer will run. https://www.maketecheasier.com/how-to-find-out-maximum-ram-capacity-of-computer/
2/25/2023 9:54:52 AM • Gateway... • Answered on Feb 25, 2023
I need a gateway laptop recovery cd
Gateway does not provide recovery CDs for their laptops. Instead, they provide a recovery partition on the hard drive that can be used to restore the laptop to its original factory settings. To access the recovery partition, you will need to press a specific key or combination of keys when the laptop is first turned on. This key or combination of keys will vary depending on the model of laptop you have. You can find instructions for accessing the recovery partition in the laptop's user manual or on Gateway's
2/21/2023 10:42:44 PM • Gateway... • Answered on Feb 21, 2023
Gateway 500xl tries to reboot after running for 3 or 4 minutes,reboot not always successful
Thats a pretty old PC but still usable. You might have a bad video card or the heat sink has failed. Adding some thermal paste to the processors heatsink will probably fix this. If not, replace or add a video card. The video card can be found pretty cheap online.
1/7/2023 3:34:00 AM • Gateway... • Answered on Jan 07, 2023
Who made Gateway LP2407 monitor please?
Question edited for clarity. Made by Gateway in a factory in Taiwan, Korea, or China. It should be on the back label on the left side. It has a history of capacitor issues. https://www.google.com/search?q=LP2407+maker ..
11/20/2022 7:17:15 PM • Gateway... • Answered on Nov 20, 2022
2answers
My Gateway PC is making 1 long beep. I fixed it before when it was doing 3 beeps then a long pause. I fixed that one by cleaning it out but the next day its making 1 long beep. How do i fix this??
Hi, Please run a virus scan on your computer and then put it into hibernate when you're not using it. This will make your pc clean and put it in a state where even the tower is off so noise should be made. Thank you.
11/16/2022 2:57:18 AM • Gateway... • Answered on Nov 16, 2022
I have a gateway ms2273 laptop and it wont turn
You can try switching off the comp. then remove the battery at the back of the laptop then wait for a few seconds before putting it back.
11/3/2022 10:42:41 AM • Gateway... • Answered on Nov 03, 2022
My Gateway ZX6980 Card Reader will not work?
Hi, Please test multiple cards in the reader to ensure that 1 individual card isn't the problem. Then, you can restart your computer after running a virus scan. Thank you.
7/29/2022 12:41:43 AM • Gateway... • Answered on Jul 29, 2022
2answers
I have a gateway m-7315u laptop that gets overheated and shuts down when I try to edit photos or play a video.
14years old a good run, runs windows VISTA. run any oveheating test app yet to prove it is? that is first. it has no value this old and is rare, now. so are parts. but the cleaning ignored this long , is solve this way. (most)
  1. all vents cleaned of lint.
  2. take down,
  3. fan cleaned of all lint.
  4. fans copper radiator clean all fins of lint.
  5. some need new heat sink grease this old it goes dry and fails.
next to fail is CCFL back lamps dead.LCD is now dead. big battery is bad, run on AC packonly remove huge battery RTC coin cell is dead , it is 2 times its life span now. best cpu overheat app is here https://www.hwinfo.com/download/ 50c is par, 90c the CPU self shuts down. and saves its own bacon. intel Inside did that at the die level logic. below is abuse. not keeping it clean ,it can not breath, and chocks and oveheats fast. graphically show. seen vast times.dirt6lt1-undefined-undefined-1.jpg
7/7/2022 10:51:32 AM • Gateway... • Answered on Jul 07, 2022
Computers & Internet Logo
3 questions posted
Top Gateway Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Gateway Computers & Internet
Most Popular Question
wireless internet
  • Computers & Internet
